Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jan 31, 2012 | 09:33 PM
  #2776
DVG's Avatar
DVG
I want to put a set of 19"OEM RAYS from a g35 coupe on my 2003 5ATG35 SEDAN. I am not sure about the specifications of my car as is, but it came with a set of 17" 6 Spoke wheels.
Will I have to do any modifications to make these wheels fit?
Old Feb 1, 2012 | 07:12 AM
  #2777
o3LRG's Avatar
It'll fit without a doubt.
Old Feb 1, 2012 | 07:26 AM
  #2778
o3LRG's Avatar
03 coupe. If I run 18x10.5 +10 about 1.5 -2inch drop coilovers. What tire sizes should I be running and how much camber if possible. Not trying to be layd out on the ground its daily driven and has occasional road hazards. thanks in advance for any help
Old Feb 1, 2012 | 07:37 AM
  #2779
the_sedan's Avatar
Any experiences with stretchin capitol sport uhp tires? 245/35 on 20x11
Old Feb 1, 2012 | 08:06 AM
  #2780
DVG's Avatar
DVG
Sweet, no rubbing or anything? What size of tires should I put on them?
Old Feb 2, 2012 | 07:39 PM
  #2781
4DGS's Avatar
Originally Posted by G35bawla
I have a 2004 infiniti g35 coupe (no brembo) and I wanna put staggered 22" wheels on it ...(22 x 8.5 on front and 22 x 10 on back) or even wider if possible but I don't want any modifications done to my car and I don't want my wheels/tires to stick out past the fenders..I want a flushed look between the fenders and the tires...I also want the deep lip effect of the wheel, so I'm kinda lost as far as knowing what offset to ask for when I order them. Any suggestions? And yes I wanna keep the size 22" in mind because I already have 20" on the car right now...thanks for ur incoming suggestions
No offsets, I can't help you.
Dave, you'll be fine with this set up.
You don't NEED camber for this set up.
Are you running this all the way around? The front is going to look goofy compared to the rear. The rears will clear with the natural camber from the drop and a roll. Run a 275/35
Never even heard of that brand my man.
You'll be fine at stock height, eventually you'll want spacers as wells.
Run the stock sizes 225/45 245/40 or either of those all the way around.
Old Feb 2, 2012 | 07:51 PM
  #2782
DVG's Avatar
DVG
Cool, thanks
Just ordered a set
Old Feb 3, 2012 | 10:19 PM
  #2783
the_sedan's Avatar
how bout 235/35 general on 10" and 245/35 n3000 on 11"?
Old Feb 4, 2012 | 12:29 PM
  #2784
parhamm1's Avatar
Wheels: 20x9.5 +3 and 20x11 +3
Drop: on coils about 2-2.5"
Tires: what size?
I was hoping I could run 245/30/20 and 275/30/20, but I'm afraid I'll rub like cray... Do I need to go down to 225/255 or 235/265?
Old Feb 4, 2012 | 02:20 PM
  #2785
Ch3@N166@h's Avatar
Quick question. Whats a good tire pressure to leave yur low pros on?
Old Feb 4, 2012 | 06:06 PM
  #2786
04BonBG35's Avatar
I am planning on buying 19'' varrstoen 4.4.2 but I am not sure what will be needed in order to fit these wheels on my 04 coupe. I have never seen these wheels on a g35, only on a genesis.
Front size 19 x 9,5 offset + 12
Rear size 19 x 10,5 offset + 12
There is also possibility of having these with a +22 offset front+rear. What do you guys think would be better offset, +12 or +22 ?
Tires will be Nexen N3000 245/35/19 Front and 275/30/19 Rear.
I'd rather not have comments about how Varrstoen's are replicas and this and that, I just don't have 4000$ to have work varianza's....
I have been told also that camber ajustment will be needed for these ??
HELP ME OUT PLEASE !!
Old Feb 4, 2012 | 06:08 PM
  #2787
04BonBG35's Avatar
Old Feb 6, 2012 | 11:00 AM
  #2788
Gravacity's Avatar
I'm looking to put spacers on my stock Rays and I did some searching and found out 25mms are good for F and R. I find it kinda of expensive to spend $250-$300 on spacers so are these ebay ones any good? Anyone have experience with them?
Spacers
Old Feb 6, 2012 | 11:18 AM
  #2789
parhamm1's Avatar
^There is a member selling no name spacers. I believe his user name is kday. Look him up. I think he sells them for 60-80 a pair. They look legit too. No personal experience but I know people on the forum have purchased from him.
Old Feb 6, 2012 | 11:19 AM
  #2790
parhamm1's Avatar
Any assistance on my question above? I forgot to add my car is a G35 coupe, rear fenders rolled.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
