Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jan 4, 2012 | 10:53 AM
  #2731
BallerOnaBudget's Avatar
Thanks 4DGS! :bigthumpup: would you reccomend running 10 on the F and R? Also how much rubber (what size tire) do you think I'll be able to fit in there on a 20in rim? Thanks again buddy!!
Old Jan 4, 2012 | 03:34 PM
  #2732
Elmecano's Avatar
ok I am ready to buy my wheel but I have one last question.
so previously I aks you for tire size to go on 20x10 all around and you suggest me 245/40r20(post #2671)
but what it confuse me is when I take a tire calculator like this :
http://www.miata.net/garage/tirecalcold.html
it said to stay within 3% of the stock size for the rear its ok
245/45r18 to 245/40r20 = 3.9%
but for the front
225/45r18 to 245/40r20 it said 6.7%???????
so how the width of the tire can affect the speed that much...it is not suppose to be the same thing than the rear??? its the same hight??
because if I put a 225/35r20 it should be perfect but I dont want that much of strech on a 20x10 rim
I already drive slower because I have a US car in Canada so I don't really want to go even slower that much lol
Thanks
Old Jan 5, 2012 | 07:17 PM
  #2733
4DGS's Avatar
Originally Posted by NGreeeeeen
I need to get a new set of tires pretty soon anyway...so for the 20" 8.5 +20, and 9.5 +25 what tire would you recommend for my coupe all stock suspension.
245/35 and 275/30 would be my pick.
Originally Posted by SuperTrooper699
i got a sedan man
The no spacers are required. 8.5 +15 is pretty flush and you'll actually want to roll the rear fenders.
Running 10" all the way around is no problem at all, you just need to watch the clearance on the front strut.
How low do you plan to go (if at all) are you for or against negative camber? For or against stretching tires?
but for the front
Thanks
OEM rear tires are actually 245/40/19
If you don't want to stretch then go to a 245/30 it's basically the exact same overall size as the 225/35.
Sorry I don't recall the original question...
Old Jan 6, 2012 | 12:17 AM
  #2734
Ramanl's Avatar
Looking for rims and I like these http://www.tirerack.com/wheels/Wheel...3&autoModClar=
I'll probably be getting the 18's....Is their any others wheels that look similar to these?
If I got these should I get the Gunmetal or silver. I drive a 03 g35 sedan silver.
I don't know much about tires and wheels, but I think this style would look nice.
What size wheels and tires should I get? The car is not lowered and don't plan on that any time soon.
Old Jan 6, 2012 | 12:37 AM
  #2735
DaGdriver's Avatar
i would recommend 18s or 19s but its up to you. i would recommend getting VarrsToen.
Old Jan 6, 2012 | 11:58 AM
  #2736
Not lowering at all buddy, I'm shooting to keep camber within factory specs...stretching isnt out of the question!
Old Jan 7, 2012 | 10:43 PM
  #2737
Gst88's Avatar
Has anyone tried the spacers from Z1 motorsports?
also would wheels size 19x9 front and 19x10 rear fit on a coupe?
Old Jan 8, 2012 | 12:12 AM
  #2738
sh0rtys463's Avatar
My current setup is 19x8.5 +30 and 19x10 +40 and I'm lowered a bit. I have 245/35/19 and 275/35/19. I like the setup, feel like I could use a spacer in the rear though. Suggestions? Also, I would like a little more sidewall for ride comfort. Again, suggestions? Thanks for the help.
Old Jan 8, 2012 | 05:54 PM
  #2739
Lone Wolf's Avatar
Anybody know where I can find the torque spec for Volk wheels? I'm thinking about getting my GT-M's redone this week. I did some searching and found a few threads with only a few responses but no definite answers.
Old Jan 8, 2012 | 11:17 PM
  #2740
Will_Ireally_AM's Avatar
if my off sets are currently +18 20x9 in front and +20 10.5 in the back what spacers will give me a more flush look but with out a huge poke i have 245 in front and 275 in back and im lowered on g35 stechs with rolled fenders
Old Jan 10, 2012 | 07:27 PM
  #2741
4DGS's Avatar
Lots of options out there, I'd look into forgestar for the best value and quality of wheel.
Aim for the specs to be in or around 18x8.5 +25 and 18x9.5 +35
If you're unsure of any wheel brands or whether or not something will fit, just come back to this thread and post up, I'm always around to help.
You have provided nothing of use to him, don't give advice in this thread.
If you don't plan to lower it then stretching is out of the question. Too many questions have been asked though I can't recall if you had a coupe or sedan? If you could make it easy for me and just lay out the questions and give me all the info in one go I will do the same in return lol
Spacers are pretty solid, Z1 is a pretty good company.
However I can't answer your question. Are you looking for the offset that would look good with those widths? if so, please quote both of our questions.
Coupe or sedan?
if you have room for a spacer feel free to throw one on, without knowing coupe or sedan or suspension specs I can't recommend a size though.
As for the tires, you really should be running a 245/40 up front anyways. The rear is a good size but if you up the front sidewall they will actually match in overall diameter.
Do you plan to do it yourself?
Torque specs change quite often, depenings on the alloys used and the type of hardware.
Volk only ever wants to release the info of brand new hardware torque specs, since you most likely will reuse the old hardware I would recommend backing it off a little.
Rays suggests 45-50ft/lbs. This is substantially higher than all other wheel manufactures. When I did my CCWs I did 15ft/lbs then 35ft/lbs. Remember you need to cross torque these, then cross torque them again at the final torque spec.
To be safe I would do 20ft/lbs and then 40ft/lbs.
Are the fenders rolled? with totally rolled fenders you should be fine fitting a 10mm spacer in the back and 10 in the front is probably not an issue.
Old Jan 14, 2012 | 12:16 PM
  #2742
Carrottop401's Avatar
My setup:
2004 g35x
20x8.5 Helo HE851 Gloss Black w/Machined Face
245/35/20 Hankook Ventus v12 evo k110
What do i need in order to make this work if i want to drop my car 1.5"?
Old Jan 14, 2012 | 05:36 PM
  #2743
Ramanl's Avatar
So I found a good deal on TSW Snettertons on a local ad.
heres the info
5 by 120
18 x 8.5 front
18x9.5 rear
ET 3.0 fronts
ET4.5
Anyone have experience with TSW wheels? Weight?
Old Jan 14, 2012 | 07:27 PM
  #2744
Ken_G35c's Avatar
04 g35 coupe w/ brembo
xxr 521
18x8.5 front +25 225/45
18x10 rear +25
currently no spacers
stock suspension
widest tire I can go in the rear???
and height of tire as well???
Old Jan 14, 2012 | 07:58 PM
  #2745
jimmyboi860's Avatar
heres the info
5 by 120
18 x 8.5 front
18x9.5 rear
ET 3.0 fronts
ET4.5
Our bolt pattern is 5x114.3, so those wouldn't fit.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
