Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old May 20, 2012 | 07:01 PM
  #3481
k67p67's Avatar
Originally Posted by TheGThirty5
Need new tires for 2 of my rims, i have 245 35zr 20 my question Is
Will any tire work that is 245 35 20? I keep finding tires on line
But they dont say 245 35zr 20 they say 245 35r 20 thanks in advance
TireRack
Old May 20, 2012 | 07:15 PM
  #3482
TheGThirty5's Avatar
Originally Posted by k67p67
I guess my ? Is whats the zr for in 35zr
Old May 20, 2012 | 07:20 PM
  #3483
k67p67's Avatar
Would it kill you to read a little? Click on the link.
Old May 20, 2012 | 07:42 PM
  #3484
DrewDrew's Avatar
Bahahaha. I <3 kurtis. truth.
Old May 20, 2012 | 09:04 PM
  #3485
MPG35fiend's Avatar
Originally Posted by tgmccoy
4dgs-
i want to blow up your avatar, looks like a nice rolling shot! Post a bigger pic, or link me
^ +1
Old May 21, 2012 | 12:12 AM
  #3486
Lol thanks for the link
Old May 21, 2012 | 08:43 AM
  #3487
Bunthis2's Avatar
Big question im almost ready to get wheels and was wondering if 245/35 20x9.5 +4 front and rear 275/30 20x11+6 will look stance. I have megan racing coil at home rady for install. If anyone has pics of this setup or close please share. Thanks in advance im new to the aggressive scene just wanted ideas from different Pics
Old May 21, 2012 | 03:30 PM
  #3488
DrewDrew's Avatar
It'll look off because your rear will poke, and your fronts will be tucked. you'd want a 225/35 up front to look the same. that 245 isn't a stretch, it's basically just a low offset with a fat tire. "Tucked" so to say. the rear is a mild stretch and will poke/flush.
Old May 21, 2012 | 06:26 PM
  #3489
Bunthis2's Avatar
Thanks for the help yo. I got another question would that setup work with brembos? And if i decide to change into a better BBK one day will it still clear?
Old May 21, 2012 | 06:28 PM
  #3490
DrewDrew's Avatar
Depends on the wheel disk. get that info and we'll know.
Old May 21, 2012 | 07:48 PM
  #3491
Edwadowad's Avatar
Just installed BC coils and wanted to get my wheels a little more flush. Currently running 245/35/20x9.5 in the front and 285/30/20x10.5 in the rear. Wheels are +15 all around. What size wheel spacer would you recommend running without any rubbing issues? All fenders have already been rolled flat.
Old May 21, 2012 | 08:58 PM
  #3492
4DGS's Avatar
Originally Posted by TGMcCoy
4DGS-
I want to blow up your avatar, looks like a nice rolling shot! Post a bigger pic, or link me
It's much better when small lol more shots to come next weekend!
What exactly does "look stance" mean?
The rear you've maybe got 5mm to play with. the front should be able to fit a 10mm or so.
Old May 22, 2012 | 02:30 AM
  #3493
wussupb0o's Avatar
How much camber can i run on a coupe before i start experiencing significantly reduced tire life and noticeable uneven wear? Spoke to a friend that had -3.5 on the rear and his tires looked perfectly fine.
Old May 22, 2012 | 02:51 AM
  #3494
DrewDrew's Avatar
I think he forgot the "d"...meaning what those specs look like stanced. . Odd way of asking what those specs look like on a car.
camber doesn't reduce tire life. it only concentrates the wear on a certain area/contact patch. toe is what kills tire life. that's why and how you see you guy running -5* and more camber, but daily drive them and not go through tires every month. get your toe set to .02 and you're golden. coughblaincough.
also remember they're on a routine of flipping their tires ever 5k miles or so, to wear evenly on both sides - but they have to be symmetrical. you can't flip asymmetrical tires.
  #3495
4DGS's Avatar
-1 will eventually show uneven wear, hell -.5 will eventually show uneven wear. It's not about how much camber you are able to run it's just about if you're willing to burn through them.
You'll easily get 15k miles out of a set of tires at -3.5 degrees. Keep in mind summer tires have zero mileage warranty because a stock G35 is going to burn through them in under 30k anyways.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
