Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Dec 22, 2010 | 07:03 PM
  #1336
trentor's Avatar
You too 99probs. for future reference, here's how I figured the 0.6". Hopefully it'll help you in figuring out what fits...
http://www.rimsntires.com/rt_specs.jsp
Old Dec 24, 2010 | 11:39 PM
  #1337
Eskimo10's Avatar
Hey all tire/rim pros. I'm looking at getting some rims with a +45 offset, what size spacers would I need to make it flush with the car? I'm planning on putting 18" rims, with 225/45/18 in the front and 245/45/18 in the rear. Thanks for the help!
Old Dec 25, 2010 | 12:30 PM
  #1338
SkylineGTR2789's Avatar
You won't be flush with spacers with those sizes .. even if you got 30mm spacers you would still be at +15 which is decent but that's too much space to compensate
Old Dec 25, 2010 | 02:37 PM
  #1339
Lone Wolf's Avatar
Dear Fitment Guru's, I looking at getting a front camber kit(SPC). My front is 9.5 +23 wrapped in Hankook v12's 245/35/19. I'm lowered 1 inch in the front on TEIN FLEX Coilovers. My front left is at 1.8 negative camber, and my right front is 2.0 negative camber. Would I have any rubbing issues if I add some positive camber? Thanks for the input guys.
Old Dec 25, 2010 | 04:17 PM
  #1340
teahead's Avatar
Can't you tell by looking and measuring?
Old Dec 25, 2010 | 04:56 PM
  #1341
4DGS's Avatar
Too both of you.
COUPE OR SEDAN?
Ip350gt, you can probably go to -1 and be fine. Worst case, pinch your fenders and give er.
Old Dec 25, 2010 | 04:57 PM
  #1342
Eskimo10's Avatar
Oh, I didn't know that would matter.. but its an 03 Coupe
Old Dec 25, 2010 | 05:01 PM
  #1343
4DGS's Avatar
I need to know how wide the wheels are as well.
Old Dec 25, 2010 | 05:54 PM
  #1344
Eskimo10's Avatar
They are 18x8..I'm also looking at a 18x7.5 set as well with the same stats as above.
Edit: also is it going to matter that I'm going to lower the car as well?
Old Dec 26, 2010 | 08:49 PM
  #1345
VEN0M's Avatar
Here WERE my specs for the front tires:
Hankook 245/35/zr20 Wheel diam : 9
NOW im running
Generals 225/30/ZR20 same wheel.
My problem is that i want the same great stretch look i have in the back, as well as a bit more tire to fill in that MASSIVE wheel gap in the front. I dont know if the reason for the HUGE difference in tire is in hte profile, the diameter, or hell maybe its just that they are different tire companies.
The car will be lowered a bit more, depending on how the newer tires sit. Im not going ot to lip to fender, but i want the same look i have with the rear.
Here is what the rear looks like: 275/30/20 Hankooks
Old Dec 27, 2010 | 02:31 AM
  #1346
Lone Wolf's Avatar
Originally Posted by 4DGS
Too both of you.
COUPE OR SEDAN?
I have a coupe...
Old Dec 27, 2010 | 10:31 AM
  #1347
Kenny_Cox's Avatar
I've posted here a few times. Hopefully this time I get a response
20x8.5 and 20x10.5 on a 2006 g coupe how low of an offset can I use to require no stretching and still be as flush as possible? I can roll fenders but I will not stretch a tire.
Old Dec 27, 2010 | 09:14 PM
  #1348
T4RUSAF's Avatar
245/40/19 & 275/40/19; will they rub?
Hello all, quick question.
I've searched for an hour and can't find an answer to my question. I'm currently running 245/35/19 & 275/35/19 and need new tires. I want to move up to 40 series because at some point I know I'm going to slam into a damn pothole and bend my rims. Also, I am hoping to quiet up the ride a bit with a thicker tire. Will these tires fit without rubbing? Currently on my 35 series tires I don't get any rubbing at all. Here is my setup:
- s-tech (finger gap all around)
- 9.5F and 10.5R widths (not sure on offset, but its the common Racing Hart
RS-721 offsets)
thanks in advance for any insight!
Old Dec 27, 2010 | 10:39 PM
  #1349
Slammedg35coupe's Avatar
fitment question
i have a set of tires here 245-30-20 & 295-25-20 or should i run a 285-25-20 ? i would like to run a 9x20 front and 10.5x20 rear. i would like to get the correct offset to run on the coupe with brembo's. i want the wheels to fit right on the fender. anyone also has wheel option's please feel free to post a brand.
Old Dec 28, 2010 | 12:11 AM
  #1350
carboy19's Avatar
newbie 19's rim questions
hey guys im getting my 2006 g35 coupe tomorrow.
tried to read 30 pages of wheels post and i just got dizzy and didnt really get the answer i needed..hoping you guys can help me out
planning to get 19's staggered set up. and tien coilovers
whats a good simple set up width and tire sizes
ive seen 19x 8.5 front and 19 x 9.5 rear offset of 33mm
any ideas would help me narrow my options..
thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
