Not so OE19s tire size
Old Sep 11, 2009 | 11:36 AM
Dan_G's Avatar
I am sending my oe19s (fronts) to weldcraft to get the widened and I'm wondering if I should do + 2 or 2.5". I am dropped on z s techs and have 20/25 mm spacers. I am moving my rears up front and vice versa. Should I do 10 or 10.5? What would be a good tire size for either set up
thanks in advance
Old Sep 11, 2009 | 06:55 PM
redlude97's Avatar
If you are moving the 8.5's to the front, then I would just go 10". The widest you can in the front is a 255, so the widest you should go on the rear is 285. Any more stagger than that isn't optimal for handling. There is no point in going to a 10.5 because a 10" wheel holds a 285 just fine, and you will be adding less overall weight to the car
Old Sep 11, 2009 | 07:49 PM
Dan_G's Avatar
well, im planning on keeping the OE 245/40 set-up for the "fronts", so 285/35s would be pretty good?
Old Sep 11, 2009 | 07:59 PM
redlude97's Avatar
do not run the 245/40/19 in the front, it is too tall.
Old Sep 11, 2009 | 08:01 PM
Dubi2087's Avatar
you need a 35 series tire up front
Old Sep 11, 2009 | 08:07 PM
Dan_G's Avatar
too tall for looks or fitment? i have almost brand new set of rears and really dont want to buy unless they wouldnt fit
Old Sep 11, 2009 | 08:09 PM
Dubi2087's Avatar
Fitment - since you are dropped and have spacers they will rub. Try it first before doing anything.
Old Sep 15, 2009 | 01:15 PM
LightsOut's Avatar
SIETESG
quick suggestion.
8.5 up front 245/35 25mm spacer - sell your 245/40 tires
275/35 9.0/9.5 inch width with 20mm spacers
Old Sep 17, 2009 | 05:08 PM
Dan_G's Avatar
so i went ahead and test fitted the 245/40s up front witht he 20mm spaceres and wow... its close but they fit (about .5" clearance)
sorry for iphone pics
Attached Thumbnails Not so OE19s tire size-img_0141.jpg   Not so OE19s tire size-img_0137.jpg   Not so OE19s tire size-img_0136.jpg   Not so OE19s tire size-img_0138.jpg   Not so OE19s tire size-img_0139.jpg
Old Sep 17, 2009 | 05:12 PM
LightsOut's Avatar
SIETESG
it will fit, but the issue would be VDC issues. your 40 wall might be to tall for your rear wall. 30/35 series wall.
Old Sep 18, 2009 | 09:27 AM
idrive_MD's Avatar
Yeah you are definitely going to want a 285/35 tire on the rear if you are going with a 245/40 up front. I think a rule of them is to keep the sidewall heights the same or at a delta of 5. I have 35 up front and 30 in the rears and its not causing me any issue...both tire sizes are supposed to be 26" OD on mine, but I have a slight stretch in the front so its realistically probably a little shorter than specs.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
