New setup question
Old Oct 6, 2009 | 05:03 PM
cicada06's Avatar
New setup question
Considering going to Volk GT30 19x9.5 +5 (C-disk) and 19x10.5 +8 (B-disk). I currently running OEM 19s with 20mm and 25mm spacers and lowered on 350Z H-Tech. Would i have any rubbing issues? Trying not to have to roll fenders.
Old Oct 6, 2009 | 06:37 PM
nghiars's Avatar
wat tire sizes do you ant to run?
Old Oct 7, 2009 | 11:07 AM
cicada06's Avatar
thinking about 255 or 265/35 fronts and 275 or 285/35 rears
Old Oct 7, 2009 | 01:08 PM
LightsOut's Avatar
SIETESG
with those offsets your gonna have to roll your fenders.
I suggest stick to 245/275
give some negative camber and you might get away without rubbing
Old Oct 7, 2009 | 01:13 PM
cicada06's Avatar
what about with a +14 F and +17 R offset? I want them to be as flush as possible w/o spacers.
Old Oct 7, 2009 | 01:30 PM
LightsOut's Avatar
SIETESG
to sit flush as possible you'll have to roll fenders.
if you want a semi flush where you dont have to roll fenders. I suggest
19's
8.5F
9.5R
245/275
18-22 offsets
most common here with fenders rolled
9.5F 10.5R
245/275
10-18 offsets or higher offset like 20-28 to sit semi flush without fenders rolled.
these are are just estimates of offsets you can go work with, without getting to technical.
Old Oct 8, 2009 | 09:26 AM
cicada06's Avatar
Thanks for all the help. Based on the spec sheet i do not see offsets in those measurements for 8.5/9.5 combo but you said they were estimates so cool. (http://www.rayswheels.co.jp/cgi-bin/...modelName=GT30)
After some more thought and searching around i'm prepared to roll fenders but not flare since i really want the 9.5/10.5 combo. So i'm leaning towards +17 +18 offset???
Would i have a problem with BBK if i choose to add them in the future?
Thanks again for all the help...
Old Oct 8, 2009 | 11:19 AM
LightsOut's Avatar
SIETESG
good selection of offsets along with wheel widths.
if you wanted to go more aggressive you could just run more negative camber with lower offsets or add spacers, if you wish.
as for bbk, you sholdnt have any problems unless your wheel design is caved in and prevents you, but dont think that will happen.
also,
if you find wheels that you like and the offset is higher. Other option tires size is 255/285 tires or wider
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Spartan268
Aug 20, 2015 09:14 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
