Wheels/Offsets: Will this fit
the rear will sit over 2" farther from stock (52mm)... OEM sits about 10mm sunk in from flush to fender line... so you need to account for about 27mm (a little over an inch).
I don't know how many degrees negative camber equates to an inch... but its going to be more than 3.
ill Sedan
If I dont get rid of them, I am going to keep my coupe 18s ( 18x8 +30) but run a 40 series tire (have 45 series now) and drop on either H-techs or Eibach Prokits. Sitting flush right now but too much wheel gap/thick side wall.
ill Sedan
I'm running a 8.5 +15 / 9.5 +20 with -2.75 degrees of neg camber F/R and am lowered 2+ inches. So I believe he should be able to go low enough for it to look good without running more than 3 degrees neg camber.
ill Sedan
Someone needs to post a chart with mm/in to degree... I figured 1" would be around 3° and of course anything more would be further…
