Varrstoen (te reps) in +22 or +12 with tein s techs for g35 coupe?
Old Jan 26, 2012 | 08:08 PM
  #121
Drew113's Avatar
Ban Hammer Expert
What are the exact specs your trying to go with ultimately?
Old Jan 26, 2012 | 11:37 PM
  #122
chatt350gt's Avatar
who are you referring to? =/
Old Jan 26, 2012 | 11:44 PM
  #123
Drew113's Avatar
Ban Hammer Expert
^was referring to you chatt
Old Jan 27, 2012 | 12:30 AM
  #124
jentz's Avatar
Chatt you shoulda kept those 15mm for your 225... That would be ideal... -3 on 235 is not really functional unless you have all flat roads and driveways... Definately wouldn't recommend a newbie doin that
Old Jan 27, 2012 | 12:34 AM
  #125
Drew113's Avatar
Ban Hammer Expert
i was running 15mm with my +12s and 275/30 in the rear and i was almost able to get away with it....just barely was rubbing trying to figure out if im gonna add some camber or switch out the tires...
Old Jan 27, 2012 | 12:44 AM
  #126
jentz's Avatar
15mmfront 20mm rear 225 245 is the fit that's the ****... Customized rear fender pull so specs will be had fo shizzle
Old Jan 28, 2012 | 02:53 AM
  #127
jentz's Avatar
this is a varrstoen thread so delete your shiny po-dunks til u get some ALGY
Attached Thumbnails Varrstoen (te reps) in +22 or +12 with tein s techs for g35 coupe?-securedownload.jpg
Old Feb 7, 2012 | 01:08 AM
  #128
Kyletk808's Avatar
jentz
quick question? Originally your wheels were hyper black I believe...Is that still the current finish with your most recent setup? BTW loved the progression photos on this thread! awesome info and sweet rides
Old Feb 7, 2012 | 09:50 AM
  #129
jentz's Avatar
Yep these are the hyperblack all the way thru the thread. They call is black referring to the inner wheel-outer spoke is a powder coated mirror finish and the top lip is black which looks killer when you stretch thanks
Old Feb 8, 2012 | 09:20 AM
  #130
CaseyinGA's Avatar
To chart or jentz: as you said earlier running a +12 would allow a 275/30 or 275/35 rear with a conservative drop plus a fender roll. I'm not opposed to pulling either. I just want to drive it with a passenger on Tampa roads with minimal/ no rub. Is this possible or do you have any other suggestions. Btw I like the stance look. I just want function and minimal headache. Thanks in advance.
Old Feb 8, 2012 | 10:28 AM
  #131
jentz's Avatar
If you look in the earlier pages you will see my car with 2753519 +12 w/roll it takes the whole fender.. It also looks like crap.. For function looks and performance get away from such a big rear.. 275 is way to big if your trying to achieve a clean look go 245 or 255 and add a spacer
Old Feb 8, 2012 | 11:28 AM
  #132
Drew113's Avatar
Ban Hammer Expert
yeah...with the 275 and +12's its pretty much impossible to add spacers with that fat of tire...would need at least a 265 or 255 to squeeze in a 10 or 15mm spacer in the rear
Old Feb 8, 2012 | 12:10 PM
  #133
jentz's Avatar
Anything above a 25535 rear will look like hell trust me and your vdc will hate you also
Old Feb 8, 2012 | 12:12 PM
  #134
Drew113's Avatar
Ban Hammer Expert
....I know tried fitting 15mm rubbed continuously....then tried 10mm and even that rubbed with my 275/30
Old Feb 9, 2012 | 07:56 AM
  #135
CaseyinGA's Avatar
I appreciate the help guys. Ill probably go with a +22 with a 5mm spacer. My good friend is a Nissan master tech. He said a 275 rear was OK. He has a 285 on his 350z. He's had no vdc issues. As I said before the stance look is great. I just don't want a headache when it cone to where I can and can't go along with scraping. My girl works downtown and parks in a garage. I pick her up sometimes and love to set off car alarms with my exhaust ( yes, I'm that guy ). Lastly, both your cars look great! Thanks again.
