Tire size question
Old Mar 10, 2012 | 07:55 PM
RastaManMax's Avatar
Tire size question
Hi all,
I've done quite a bit of reading on tire sizes for the G and I'm slightly confused. Seems that people are saying to stay within 3% or you risk throwing off the VDC but some people are suggesting 245/35/19 tires for the 03-04 6MT which has a stock size of 225/45/18. According to the my calcs that's 4.1% smaller than stock so what gives?
Reason i'm asking is because i'm about to get some tires from discounttiredirect and i'm thinking of getting the FK-452's in 255/35/19 F and 275/35/19 R. I've seen a couple people now say that 255/40/19's might be a bit big-ish but at the same time I don't want to throw off the VDC if I get the smaller size (the 255/40's are closer to OE spec). I'd rather get the 255/35 if I can pull it off without screwing up the VDC.
These tires will be used on either a 19*9 F or 9.5" wide front (since 9.5" is the minimum for the deep concave 19's) and 19*10 R Forgestar F14. I don't really want the stretched tire look so i'm thinking the extra width from the 255 may be worth it to keep my options open on the fronts. Plus I hear the FK's run slightly smaller than some other tires out there.
Suggestions? Will I be okay with the 255/35/19 F and 275/35/19 R or should I go with 255/40/19's or 245/40/19's?
Old Mar 10, 2012 | 08:26 PM
herrschaft's Avatar
As long as the front and rear tires don't have more then a 3% difference, then you're good.
Old Mar 10, 2012 | 09:52 PM
I see. I guess that makes sense then because there's about a 2% difference between the 255/35/19 and the 275/35/19 sizes. Correct?
Old Mar 10, 2012 | 10:02 PM
herrschaft's Avatar
^Yes
Old Mar 11, 2012 | 04:25 PM
Thanks again. Ordered. Now time to finalize wheels.
Old Jun 27, 2012 | 06:37 AM
Hiro's Avatar
This is an older thread, but it pertains to my questions. I too have an 04 coupe with the stock 18 inch wheels. 225/45 fronts, 245/45 rears. I will put on some wheels spec'd at 19x9 fronts, and 19x10 rears. It seems like the 275/35/19 will work well in the rear. But from the 1010tires site, it seems as thought the 255/35 up front is closer to spec when compared to the 245/35 fronts. Am I reading this improperly?
Also, if 255/35 are a better choice why does it seem the 245/35/19's are more popular? Is it because the 255's rub? I need to buy tires in the next few days so any advice would be welcomed. Also to the original poster....I don't think its 4%...I think its 0.4% which would be less that half a percent if I'm not mistaken.
Thank.
Old Jun 27, 2012 | 04:15 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We've always sold one of the two combos in 19" to keep diameters correct and it's worked well.
245/35-19
275/35-19
285/35-19
I've seen others on the board use 255/35 and 275/35 with no issues.
Old Jun 27, 2012 | 05:28 PM
irishsig's Avatar
I think most people get 245s up front because they are a more common size and hense a little more affordeable.
I'm currently running 255 35R19F & 275 35R19R with no probs.
I can't drop my car any lower because of my driveway so like how the 255s give me less wheel gap in the front.
Old Jun 28, 2012 | 03:42 AM
Hiro's Avatar
Thanks for the info. Hey Neal, do you have any recommendations for an all season tire in 245/35/19 and 275/35/19 ? Where I live I need all season so its the best route for me.
Irish, do you have any problems with rubbing? I looked at your garage and your G looks nice That is plenty low for me. Did you have to roll the fenders or anything like that? Thanks.
Old Jul 4, 2012 | 12:04 PM
I'm currently running 255/35/19 and 275/35/19 with no problems. I went with 255's because i'm running a 9.5" up front. If you're running a 9" wide wheel, the 245's would probably be a better choice.
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
