NOOB tire size question. 245/45/19 on the fronts?
Old Jan 2, 2014 | 01:40 PM
canehdian_guy's Avatar
Hey guys,
I found a really good deal on a set of 2 245/45/19's. Would these be okay to run up front on the stock Rays with a recommended tire size of 225/40/19?
I am running 245/40r19's in the rear. I've heard running 245/40r19's up front opposed to 225/40r19's will eliminate understeer. I just want to confirm that the sidewall size will not too large that it will cause issues.
Thanks
Old Jan 2, 2014 | 01:51 PM
Frankieg35's Avatar
I think they are to big for the fronts.. Im not 100% though..
Old Jan 2, 2014 | 02:24 PM
TORETTO's Avatar
I'm running 245/35 hankook V12s on my OEM 19 Rays fronts. 245/45 is going to be super fat sidewall.
Old Jan 2, 2014 | 03:00 PM
Thanks guys. I figured the sidewall would be fairly big. Is it going to be large enough that it will noticeably affect the performance?
Old Jan 2, 2014 | 03:01 PM
TORETTO's Avatar
How hard do you drive. Your speedometer will be incorrect.
Old Jan 2, 2014 | 04:12 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yeah, that's a bit taller than normal up front. Makes for a fine rear size though.
Old Jan 3, 2014 | 02:53 AM
Thanks everyone.
Also, I know that people will run 255/35/19's on their 245/40/19 wheels for increase traction. Does this negatively impact lateral traction? I know running a taller sidewall will cause the sidewall to flex more, however im not sure about wider tires.
Thanks again
Old Jan 3, 2014 | 03:07 AM
herrschaft's Avatar
Originally Posted by canehdian_guy
Thanks everyone.
Thanks again
I doubt you will notice a difference when it comes to traction from a mere 10mm, but the lower profile will make the car feel "tighter" and will have a little better steering response. Overall traction is mainly the type of tire and the suspension setup.
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
Jnm07
Aug 6, 2015 03:03 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
