OEM 18 Wheels
Old Jul 20, 2015 | 06:13 AM
Hatchman's Avatar
Originally Posted by BabySkyline
Thank you. I didn't see such bolt however, I would have known what to do with it. I did just notice that the center holes of one wheel was shallower, the other one deeper. As if one has a 30mm offset, the other one a 32mm, even though both wheels indicate a 30mm offset.
Am I going crazy?
ET is measured from the center of the wheel to the mounting surface, the depth of the holes around the mounting surface don't matter. The hole can be deep or shallow, but ET / offset is only measured from the flat surface that mounts right up to the hub.
Heck, those holes could be hollow and go all the way through the face of the wheel, wouldn't change ET.
Old Jul 20, 2015 | 11:13 AM
BabySkyline's Avatar
Thank you for being patient and the explanation. Helped me understand this concept much better!
Now that it's clear that the offset is the same both in the front and the rear, I was wondering if that does change the fact that one hole being deeper than the other prevents you from putting a wheel on.
In other words, because one wheel is deeper, I can't put it on a wheel hub, because the wheel will be "sticking" out.
Old Jul 22, 2015 | 10:40 AM
Did anybody have a similar experience? Or was everybody just able to put on a rear wheel in the front without problems?
Thank you
Old Jul 23, 2015 | 09:30 AM
Hatchman's Avatar
Originally Posted by ScraggleRock
Unscrew this bolt. Rear wheel will fit front hub.
Xfactor
Dec 1, 2019 12:52 PM
EPG35
Aug 16, 2015 04:52 PM
TheKnite
Aug 14, 2015 07:59 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
