$250 for spring installation?
Old Mar 16, 2005 | 12:28 PM
dirrtybear's Avatar
raises all-in
A local tune shop quoted me $250 to install springs (Tein H-Tech).
Is this a good price? Thanks.
Old Mar 16, 2005 | 01:52 PM
kenchan's Avatar
Usually takes about 1.5hours to 2 hours at $65-85/hr... so that's a pretty big rip-off.
Old Mar 16, 2005 | 02:11 PM
AmistadUSA's Avatar
Try to get down to $200, $250 shall apply to Euro cars like MB or BMW If you are in LA, let me know.
Old Mar 16, 2005 | 03:15 PM
VinNYCG's Avatar
G SQUAD
Really that cheap??? Thats not bad $65-$85 per hour.
-Vin
Old Mar 16, 2005 | 03:20 PM
GXCLUSIV's Avatar
Too high. $120 is reasonable. Only takes 1.5hrs to install. Shop around.
Old Mar 16, 2005 | 03:57 PM
dirrtybear's Avatar
raises all-in
I just spoke to the guy again. He said it's a 2.5 to 4 hour job. I asked him why. He said it's because they have to take apart the interior on the rear side to get to the tops of the strut towers.
Old Mar 16, 2005 | 04:37 PM
Gsedan35's Avatar
No matter what shop does the work, make sure they do NOT use a air ratchet to tighten the nuts and bolts down. I had a member's sedan at my house to do a shock intall on and had ruin a few nut's that were put on way too tight. I couldn't even remove the rear shocks because they were too tight and the bottom mount bolt was put in backwards preventing me from getting the leverage I needed.
Old Mar 16, 2005 | 06:17 PM
Gman2004's Avatar
Is this just for springs? What about the Tein Basic coilover set? How much?
Old Mar 16, 2005 | 06:40 PM
GXCLUSIV's Avatar
Should be same price for coilovers. With EDFC is another story.
Old Mar 16, 2005 | 07:09 PM
1nate7's Avatar
Not with just a spring install.
Old Mar 16, 2005 | 08:22 PM
dklau33's Avatar
There is no need to do anything to the interior in order to install rear springs. Everything can be accessed through the wheel well. Accessing the top of the shocks is only something reserverd for adjustable shocks where the **** is at the top of the piston such as the Tokico or Konis. And that is only for a matter of convienence, not necessity.
Old Mar 16, 2005 | 09:50 PM
kenchan's Avatar
He's thinking of a wrx or sti.... he sounds lame, find another
shop.
Old Mar 17, 2005 | 07:41 AM
dirrtybear's Avatar
raises all-in
shop.
That's too bad. I actually found out about this place through this very forum. It was recommended.
Old Mar 17, 2005 | 11:38 AM
kenchan's Avatar
See if you can talk to the actual tech instead of the clerk that specializes in
decals and pedal covers... ?
snic09
Nov 8, 2017 01:46 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
EPG35
Aug 16, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
