Alignment with kics spacers
Old Jun 21, 2005 | 09:26 PM
firefox's Avatar
Question Alignment with kics spacers
So I got these 15mm kics spacers for my front wheels. These are the ones that you bolt onto the existing studs. The spacer itself has studs for the actual wheel.
I notice that after I installed them for about a month I started getting a lot of wear on the insides of the tire. The answer may be obvious, but I was wondering if you are suppose to get an alignment with the spacer on, or if it doesn't matter.
Perhaps my alignment is just off.
Old Jun 21, 2005 | 10:11 PM
kenchan's Avatar
I doubt its your spacers. Have your alignment checked. is your car lowered?
Old Jun 21, 2005 | 10:45 PM
firefox's Avatar
Nope not lowered. I guess I'll stop by Firestone to get it aligned.
Old Jun 22, 2005 | 02:05 AM
kenchan's Avatar
yep, your toe-in is too much. have them set it at 0.03 per side total 0.06 degrees on
the front.
Old Jun 22, 2005 | 03:04 AM
sen_jen's Avatar
Meatshake Enterprise
damn, how do you like the Kics Project spacers?? those are dope.
Old Jun 22, 2005 | 05:52 AM
firefox's Avatar
Assuming that it's not causing these wear issues, they're great.
My offset in the back is real aggressive, +15 on a 9.5" rim. I figured I'd try to even it out on the front wheels. +40, on a 8.5" rim without the spacer, +25 with the spacer. I think by widening the front track, it's suppose to introduce a little bit more more oversteer which equals more fun for me.
Old Jun 22, 2005 | 06:15 AM
firefox's Avatar
the front.
I was just reading up on camber, caster, and toes. Being the amatuer, I thought that it may be too much negative camber. Do you think it is really too much toe-in since the wear is on the very edge of the tire?
If it is a toe in problem, perhaps the spacers may have amplified problem? Since it is further away from the original plane.
I was hoping to get another thousand miles out of the tires, but I think I may need to replace them. It must have been the pothole that I ran over a month ago. I'll probably get the lifetime alignment at Firestone.
Old Jun 22, 2005 | 10:27 PM
firefox's Avatar
My toe specs were off.
-0.01 on the right front and 0.18 on the left front. Hopefully my wear gets better now (or rather doesn't get any worse).
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
