DIY: Rear Wheel Bearing Removal
Rating: Thread Rating: 4 votes, 5.00 average.
Old Aug 10, 2010 | 10:51 AM
  #61
drsifu1's Avatar
Staff ALUMNI
20 Year Member
Originally Posted by kennymo
i have tried and tried to get the hub off. the 4 bolts are still in. and the hub is still on. the axle is pushed in as far as it can possibly go and the hub will not budge. i tried to just get the 4 bolts on and take the whole assembly out as 1 but even those were so damn tight that those wouldnt budge either. any ideas?
post some pictures so we can all see what is going on.
Old Aug 27, 2010 | 01:50 AM
  #62
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by jt money
where did u order your wheel bearing from?
see some on sale at auto parts giant for 60, anyone know where we can find a better deal? On my case i need a front driver side
Old Aug 27, 2010 | 10:08 PM
  #63
Greggybase's Avatar
Just picked up a Bearing, Hub and Seal at Pepe Infinity in White Plains, NY. Apparently NY prices are higher...$325 for just the parts. Bringing it all to a local mechanic on Monday. (I'm handy, but don't have the time or space to do this job).
Old Aug 28, 2010 | 01:01 AM
  #64
culi's Avatar
I bought the rear bearing and hub from Infinitipartsusa.com for $200 bucks shipped. I have installed the new hub/bearing assembly but haven't got the axel back in yet. Cleaned the axle, but haven't grease it yet. I'm going to use Valvoline SynPower grease. Hopefully it works.
Not having power tool is a pain in the ***. I have to use breaker bar on every single bolt. Used a wrench and dead blow hammer on the torque member bolt because I coudn't get the breaker bar in there.
Everything went well so far. The hardest part was getting the the axel out. I didn't want to bend it too much. So I removed the A-arm (spring support, whatever you want to call it). The axle just slide right out after that.
Tips for those who is having trouble removing the rotors; just release the emergency break. Also, the axle will spin if you don't have a power tool to remove the 6 bolts. I use a pry bar and jam it between two wheel studs on the hub and the ground. This prevents the axle from spinning when you try to disconnect the axle from the differential.
Old Aug 29, 2010 | 05:08 PM
  #65
culi's Avatar
All done. No more whining sound coming from the rear. No more axle click.
Old Sep 1, 2010 | 10:18 AM
  #66
Greggybase's Avatar
Picked up the G from the Mechanic this morning....$275 to press in the bearing and install the whole thing. Definitely worth it to me. Car rides nice, no more whining from the rear. Now I can finally hear all the noise from my cupped Goodyear Eagle F1's. LOL.
Old Sep 15, 2010 | 11:30 AM
  #67
spoolinupblue's Avatar
did you have to get the bearing pressed in to the hub?
I have been checking around...found out Oreilly has it for $65 for the hub assembly. The guy tells me it is bearing and all. I have them requesting one to see what it actually is.
Old Sep 29, 2010 | 09:31 AM
  #68
G35Bandit's Avatar
soo, i was able to get the hub off but like the OP, part of the bearing is still on it, any suggestions on how to get it off?
Old Oct 6, 2010 | 12:28 PM
  #69
culi's Avatar
That is really cheap for rear beaing and hub assembly. The rear bearing and hub come in seperately. You have to press them together. Only the front comes as an assembly.
Old Oct 6, 2010 | 12:31 PM
  #70
culi's Avatar
if you're planning to re-use the rear hub, go to dealer or machine shop and have old bearing press out, then press the new bearing in.
Old Jan 17, 2011 | 09:26 PM
  #71
surma884's Avatar
I was getting this weird noise from my front right tire. I thought it was uneven tire wear, but when I checked the tire it looked good. I took it to a shop and had them look at it. They said the wheel bearings are bad. So I'm going to be replacing the bearings on the front passenger side. Should I replace the front driver side too?
I'm going to first call some shops here to see how much it is to press the hub to the wheel bearing assembly. If it is more than the cost of getting a new hub and bearing assembly pre-pressed, I will just get it pre-pressed.
Old Jan 22, 2011 | 10:34 PM
  #72
medianjoe's Avatar
My noise was..... a small motorcycle was chasing me between 35mph~60mph.
I decided to replace the rear left wheel bearing. Here is my procedure.
Step0) Put the gear in neutral. Support front weels and rear right wheel(safety).
Step1) Loose wheel nuts a little (21mm socket). Don't remove them.
Step2) Jack up
Step3) Remove nuts & wheel. Remove center wheel cap(infiniti mark). Remove cotter pin.
Step4) Install wheel again. Jack down
Step5) Remove axle nut (32mm socket / Rent for $0 at Autozone)
Step6) Jack up, Remove nuts & wheel.
Step7) Remove 2 caliper bolts (19mm socket). Secure caliper with wire.
Step8) Remove roter (hand or rubber hammer)
Step9) Remove 6 bolts/nuts on axle shaft - differential (14mm socket, 14mm wrench)
Step10) Support drive axle with something not to dangle (jack stand or paper box)
I tried to push the axle with 3 leg jaw puller but it was impossible. It's stuck.
PS: Don't even try this if you want to use the hub again. It might bend the hub.
Step11) Slam the drive axle. (8lb sledge hammer / $22 at Lowe's). I hit 15 times. lol.
Step12) Drive axle should not be blocked by anything (Exhaust pipe, differential, etc)
Step13) Remove 1 bolt/nut on lower link (19mm socket, 19mm wrench, jack)
Step14) Remove drive axle (hand, rubber hammer, or jaw puller for $0 at Autozone)
Step15) Remove 4 bolts on the rear side of hub bearing assembly (17mm socket)
Step16) Insert 4 bolts on the hub bearing assembly again (hand)
Step17) Hit the bolts with wrench or rubber hammer (the assembly might be stuck on the knuckle)
Step18) Remove the bolts (hand)
Step19) Remove hub and hub bearing assembly (hand)
Step20) Clean the hub and hub bearing assembly with brake cleaner ($2.xx at Autozone)
Step21) Go to local shops (pepboys asked $35 / remove the old bearing and press a new bearing)
I bought the hub bearing assembly for $65 at O'reilly. It has aftermarket brand, precision, but
was made in Japan with Japan made NTN bearing. I like OEM but I didn't want to wait for delivery.
I'm going to assemble them tomorrow... lol.
Old Jan 23, 2011 | 12:10 AM
  #73
AARONHL's Avatar
Great post!!!^^^ I would like to add the following:
Yank on it and don't damage your quarter panel!
Use the e-brake to lock the axle. Might not be necessary to use a socket on both sides as the locking washers help.
I was able to fully remove the whole CV axle without disconnecting exhaust or control arms. Installation is not difficult.
A slider hammer (with a wheel stud connector) works well. Can be rented from AutoZone.
DON'T BE AFRAID TO USE PB BLASTER AND ANTI-SEIZE ON ALL PIECES!!!!! I put anti-seize in the knuckle before re-installing the hub/bearing. I also filed down any rust in the hole in the knuckle.
Old Jan 23, 2011 | 01:40 AM
  #74
tyau's Avatar
Use a socket extension
Old Jan 23, 2011 | 01:56 AM
  #75
tyau's Avatar
Originally Posted by JOKER
if there is an obvious damage to the hub than yeah but it it's only rust in most cases you can prolly save the hub I think.
Just for the record...
A hub that has excess runout of over 0.005" would require replacement. 0.005" of deflection or runout is enough to cause brake wear and vibration issues.
If a car with a bad bearing is being driven on for an extended period of time, it is somewhat likely that the hub to have some sort of runout. The easiest method would be to check for runout before replacing the hub. If the hub is within 0.004" of tolerance, then no replacement is necessary. For precise runout limit, refer to the factory service manual.
Unfortunately, it seems like that there are two types of mechanics out there. One would replace them without performing a runout reading on the hub. The other would simply not replace them because there are some mechanics out there who don't even know what hub runout is. I am not joking.
Personally, if getting a reading is of challenge, I would simply replace the hub for the peace of mind. It is cheaper to do it right the first time than to keep replacing rotors every 5000 miles.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
