Engine - Power Adders Forced Induction; Nitrous; SprintBooster; etc.
FS: Blitz SBC i-Color SpecS 15081 W/ EXTRAS
Old 06-09-2015, 05:57 PM
DrivenG's Avatar
This is a Blitz SBC i-Color SpecS P/N 15081
Used this on my TT G35 Sedan which is now stock.
Paid over $1100.00 for the entire set up.
Comes with:
Controller
SBC Brain
Single Valve Boost Solenoid
Miscellaneous Fittings and some Boost line.
All the Wiring for Everything.
The optional Oil Pressure Sensor ($130 add on)
The optional Coolant Temperature Sensor with Greddy Rad Hose Adapter. ($130 add on)
Full 42 Page Install Manual
Asking $500.00 Shipped Conus + 3% for paypal or send as gift.
From Blitzpowerusa.com
All-in-one boost controller with eye-catching graphics and functions.
Accurate boost control is accomplished by high performance solenoid valve.
(NOTE) Spec-R employs Twin Solenoid valve, Spec-S employs the single solenoid valve.
Boost measurement can be choose PSI.
Stunning graphics by full-color (65,000 colors) LCD.
Multi-angle display for various installing position/location (Display can be rotated for horizontal/vertical installation).
Fuel mileage can be displayed. (Instantaneous/ Average/ Sectional)
(NOTE) This product calculates the fuel mileage from our original method using the horsepower output., not from injector duty cycle and/or full tank method. Please understand that this mileage figure is approximate and for reference usage only. Also, following limitations apply:
1.Mileage calculation under idling (stationary) cannot be performed.
2.Under deceleration, there is a difference between actual and calculated fuel consumption. Therefore, instantaneous gas mileage varies from actual gas mileage when decelerating.
3.Average gas mileage is the average value when the main unit is on. (From IGN ON to current) Every time IGN is turned off, the previous data is cleared.
Up to 6 data can be displayed out of 16 kinds of data.
Display items: Boost, Speed, RPM, Power, Torque, Instantaneous gas mileage, Average gas mileage, Sectional travel distance, Sectional average gas mileage, External temperature input (Optional sensor required), External pressure or A/F input (Optional sensor required), External voltage 1~3 (Optional harness required)
(NOTE) Only one temperature sensor can be connected. Either press sensor or A/F sensor can be connected.
Data logger function which can graph measured power, torque, A /F, etc.
All- in one full function model including RPM/Speed MAP control function, peak hold, warning, scramble boost, limiter, record & play.
Old 06-13-2015, 08:02 PM
DrivenG's Avatar
BUMP $700 Shipped
Old 06-16-2015, 12:40 AM
DrivenG's Avatar
Need this gone bump $650 Shipped
Old 06-21-2015, 02:36 AM
DrivenG's Avatar
Fathers Day Bump $500 Shipped !!!!!!!
Old 07-04-2015, 06:18 PM
kryptonite12's Avatar
still avail?
Old 07-05-2015, 12:20 AM
DrivenG's Avatar
yes sir it is PM Me
Old 07-15-2015, 02:49 AM
DrivenG's Avatar
Bump
Old 07-18-2015, 02:55 PM
DrivenG's Avatar
Bump crack head price drop $375 Shipped
Old 07-27-2015, 06:40 AM
DrivenG's Avatar
Old 08-18-2015, 06:19 PM
DrivenG's Avatar
bump
Old 08-20-2015, 05:53 PM
DrivenG's Avatar
sold
Sagemark
05-20-2008 12:07 PM
urban
Forced Induction
31
03-23-2007 01:15 AM
theeggman
09-09-2006 08:09 AM
EverybodyWildOu
Not G35 Related
03-15-2006 02:46 AM
SURgripG35
Southern California
11-27-2005 02:49 PM
Quick Reply: FS: Blitz SBC i-Color SpecS 15081 W/ EXTRAS
