G35 & G37, Coupes & Sedans
Gas Gauge WEIRDNESS !
Old Sep 12, 2008 | 02:55 PM
jutn35's Avatar
G35 Coupe
Exclamation Gas Gauge WEIRDNESS !
Does anyone have any weird problems about their Gas Gauge on their cluster, like I filled up full tank, drive it around ,so by the mid end of the week i have half a tank or so, then the next morning i turn on my car ,its like 1/4 or even LESS ! WTF? is my little bobber in the gas tank not floating right ?
THIS THREAD IS FOR OUR G35s that do not read gas accurately on the Gauge, Directions are below FYI- You are saving yourself $400+ by doing this first. If youre going to do this repair, be careful to reset the o-ring back into the grooves or else gas will escape and make your car smell bad. When disconnecting the gas from the passenger side sensor / fuel hose, you will expect a little spillage so make sure you DONT do this on a full tank. GOOD LUCK
SOLUTION BELOW !~
Originally Posted by moses
Carefully lift the unit up. There is a long metal arm holding the float unit. Where the arm connects to the main body is a little board that you can use a q-tip to clean. Mine didn't look dirty until I wiped it with the q-tip, but hopefully that is where the problem is, because there is not a whole lot else going on on this thing.
The passenger side unit includes the fuel pump, so its a little harder. You have to squeeze the tabs at the end of the fuel line, then push it off. Keep the rag handy as fuel WILL come out if there is any residual pressure.
Then pull the unit out carefully, as its a pretty tight fit. The metal arm and cleaning spot are the same as the other side, though this piece is a bit more unweildy.
Be careful not to lose the o-ring in the tank! Replace and good luck. If this works, its a pretty easy fix <fingers crossed>. Only took about 20-30 minutes.
For those looking for a cheaper parts source for the Sensor Fuel Tank O-ring, i found these sites that sell it for less compared to the 3x dealers i called which were in the range of $19 to 21$ per 1.
http://www.amsmotorsports.com/shop/i...nk-o-ring.html
http://www.injectedperformance.com/n...for350zg35.htm
http://www.z1motorsports.com/350_g35...a9ista148sjsm0
Old Sep 12, 2008 | 04:33 PM
ricerocketdave's Avatar
My 2004 Coupe and my Fiance's 2003 350Z both do the same exact thing..
I too would like to know what that is as well..
Old Sep 12, 2008 | 05:03 PM
jutn35's Avatar
G35 Coupe
FINALLY A PERSON WHO SHARES MY PAIN , but iono either, sometiems when i have a 1/4 tank left, its on E with the little orange light warning
Old Sep 12, 2008 | 05:04 PM
Yv12345vY's Avatar
Take it to the dealer? Or, stop going out for midnight joy rides
Old Sep 12, 2008 | 05:05 PM
jutn35's Avatar
G35 Coupe
i use to do those midnight runs, but gas is still a bummer these days
Old Sep 12, 2008 | 05:10 PM
g035sedan's Avatar
Have the same issue here. One time I filled up with the low gas light on and noticed I only put in some 13-14 gallons. Dosen't our tank hold 20gals? I can't imagine 6 whole gallons sitting in the tank somewhere.
Another time I filled up till the pump clicked and got in the car and noticed it wasn't even at "F" !!!
Old Sep 12, 2008 | 05:12 PM
express705's Avatar
my car is ABSOLUTLEY retarded and its proven.
i fill up, drive home, i have 1/2 tank.
then when im driving it goes up and down and around... then when i hit 1/4 tank left, it goes NUTS and sits there for a week,.
Old Sep 12, 2008 | 05:50 PM
KSWAY's Avatar
Mine got retarded like that one time. I threaten to push it into the lake if it did it again and it hasn't done it since .
Old Sep 12, 2008 | 06:12 PM
jutn35's Avatar
G35 Coupe
AHHHHHHHHHHH RECALL RECALL RECALL on our stupid gas gauges, all expense paid by DEALERSHIPS !!!!!
Old Sep 12, 2008 | 06:13 PM
CreativeDesignZ's Avatar
fuel sending unit, bring it to the dealer, mine went bad as well as my fuel shutter valve. there is 2 fuel sending units in the tank, it can be both or just one.
Old Sep 12, 2008 | 06:40 PM
jutn35's Avatar
G35 Coupe
i have no warranty, will it cost alot ?
Old Sep 12, 2008 | 06:41 PM
express705's Avatar
billions.
Old Sep 12, 2008 | 06:42 PM
KSWAY's Avatar
Almost as much as buying a new G..
jutn35's Avatar
G35 Coupe
F*** it , lol
Old Sep 12, 2008 | 07:00 PM
g035sedan's Avatar
Is it really a recall?!?! well if so..you wouldn't have to pay anything even if it's out of warranty.
