911: How do I disconnect O2 Sensor wire in Cat?
Hi guys, I have everything taken apart now for replacing my cats but I can't seem to disconnect the O2 sensor from the harness. I removed it from the retainer on the transmissions but I can't seem to get the o2 sensor plug out of the wiring harness?
Need help - anyone know how to do this?
If you’re trying to disconnect it where the o2 wire clips to the wiring harness connector, I found it easiest to remove the bracket from the oil pan first. Where my thumb is, right at the very end, that is where you need to push down. It acts kinda like a seesaw, pivots in the middle. It was still very difficult for me to pull it apart because I have an oil leak and they were suctioned together from oil being in there. I’m not sure why the engineers decided to put that clip facing up but what can ya do.
Danielek
05-01-2022 01:28 PM
n2fooz
09-04-2015 07:46 PM
