Pioneer AVIC-D1/AVIC-Z1 with Double Din Conv. (PICS)
Rating: Thread Rating: 3 votes, 5.00 average.
Old May 25, 2005 | 12:17 PM
BlackonBlackG35's Avatar
Thanks to GRider35c, for info on how to get the missing LED for the DUAL button working.
I mounted the GPS antenna on the right corner of the dash.
Initially I was only using a Scosche NN03 wire harness.
I have now installed an interface adapter and I can tell you that it sounds better. I had a gentle hiss before which is now gone.
This helps you match the gain levels to the bose amp and helps reduce any hissing sound you may have. (not engine whine)
The VSS wire is the white wire with a green stripe on the 10x2 wire harness.
Old May 25, 2005 | 12:18 PM
I cut down my trim piece with 100 grit sandpaper to get the perfect fit.
Old May 25, 2005 | 01:37 PM
tekknikal's Avatar
nice job!
Old May 25, 2005 | 05:36 PM
Rockford amp which will power 2 Rockford subs.
I know I dont have any trunk space, but I never use my trunk anyway's.
I got the remote bass control for my Rockford Fosgate amp to fit in the ashtray!!
Now you see it.....
Now you don't.....
Old May 25, 2005 | 05:55 PM
redwillow's Avatar
20 Year Member
very sharp, that looks nice and clean in the 05 interior.
Old May 25, 2005 | 06:20 PM
limeg35's Avatar
geeee...you beat me to it , it looks perfect in the 05s dash, very nice set-up , I had N1's in my 03s, I watch the DVD excatly twice!, if you dont mind me asking, how much did yoy get that D1 for?
Old May 25, 2005 | 07:25 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
nice!!!
doc
Old May 25, 2005 | 09:41 PM
Zero2sixty's Avatar
Bout time you picked something, J/K.....
Awesome job on the install and excellent choice on the HU, I have to agree with you in regards to DVD viewing, its one of those cool features that seems to fade a day or two after having it.
Any difficulty with the A/C controller ? Also how is the clearance when the screen is horizontal and the shifter is in park ?
Old May 25, 2005 | 11:40 PM
thanks.
Old May 29, 2005 | 07:46 PM
ensor's Avatar
sweet, i'm about to grab the same unit, i just have one question. where did you mount the gps antenna?
thanks
Old May 29, 2005 | 08:17 PM
CarFanatic56's Avatar
Nice Install!...looks great!...gives me some ideas for my 05 coupe.....
Old May 29, 2005 | 09:48 PM
pfizzle's Avatar
anything different then the n1 or is it the same but double din?
Old May 29, 2005 | 10:35 PM
GRider35c's Avatar
it was my pleasure...
looks nice man, congratz!
Old May 29, 2005 | 11:10 PM
How to watch video and operate NAV while driving with AVIC-D1:
_______________________________________________
Hopefully you didn't use every wire on the Pioneer wire harness. Find the wire you didn't use, and just pull it out of the harness.
I used the auto mute lead wire. After you pull it out, you will see that the wire has a connector on the end like this...
There is 1 empty slot on the harness next to the ground wire.
Insert this wire into that slot. You should feel it "click" into place...
Ground this wire and the E-brake wire and you're good to go!!
Old May 29, 2005 | 11:12 PM
The screen does hit the shifter, so any loading or unloading of discs will have to be done in at least neutral.
A/C controller wasn't too bad, you will need a fine tip soldering iron. Its harder to remove the pieces from the stock board with out damaging it, than it is re-soldering to the new board.
Also you don't want to damage the stock board incase you want to change back later.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
