DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey
Old Jun 23, 2011 | 06:17 PM
  #241
AuAltima3.5's Avatar
So if anyone had problems I have a few suggestions below for proper fitment/button feel. This is if you have the Smart key fob style that is NOT like the OP's style (the kind with the little black button within a white holder that is soldered onto the circuit board).
Suggestions:
~ Use your old key fob's rubber to fill in the gap between the circuit board and the button on the new fob. There was a post on page 7 that showed the new style buttons sheared off to fill this gap in. I used my calipers and found this distance to be 2.7 mm on average. The lock button is about this thick. It fills the gap nicely and give decent button feel. The new key fob's rubber is much thinner and can be used as a "shim."
~ Use calipers to check distances. It made my life easier, as stated above. The button depth varies a tenth or two of a millimeter between lock/unlock/trunk and the panic button is much shallower. The calipers helped me pick and cut up the old rubber key pad to find a good fill piece. We're talking tenths of a millimeter guys/gals. Very precise. I was using a 3.2mm piece of rubber for just the lock button and the case didnt want to shut right, and it didn't work. Half a millimeter less and it was perfect.
~ Be patient. It took me three nights after work to get this right, but it's so cool...
~ As previously stated, the only soldering needed is the button battery arm. I used an old CAT5 network table for my wiring. The little wires inside of it fit PERFECT into the circuit board. I kept the insulation on the parts that I didn't want touching other circuits on the board so I don't have to worry about the tape shifting so much.
~ Use packaging tape. That chintzy scotch tape was for the birds. I have sweaty hands. It came off in minutes.
~ If you didn't see around page 7 or 9, you need to remove the new key fob's plastic batter holder that is molded in. I used pliers and an exacto. You need to remove ALL of it. Don't remove the square part that houses the internal key/lock mechanism.
Hope that helps you guys. I made alot of mistakes. I tried to solder every little wire and found that this is a very bad idea unless you have the right equipment and experience. Just using the cat5 wires and tape to hold them down made a good connection.
Old Jun 23, 2011 | 08:37 PM
  #242
stinkytofu89's Avatar
Anyone still doing this mod?
Old Jun 30, 2011 | 12:56 PM
  #243
sssmasss's Avatar
awsome but why not skip that and get the st800 smart system? got remote start, engine start, proximit function, anti theft, alarm, disabling engine in case of theft? just saying. although this is a cheaper mod for people that afraid of cutting their keys and leave them in the ignition. very creative on your part though.
Old Jul 16, 2011 | 04:16 AM
  #244
Trickstyle's Avatar
aaaaaaand how much is that?
Old Aug 8, 2011 | 02:41 AM
  #245
2plus2sixMT's Avatar
I know this DIY is old but I just finished mine. It wasnt as bad as I thought. The most time consuming part was the button alignment but not hard at all. I had to use tape as a shim between the buttons. Buttons are solid. Feels & looks way better than the old remote.
Old Feb 15, 2012 | 02:30 AM
  #246
SAMzG35's Avatar
G35
i needed a backup key and FOB when i got my car, so i bought this off ebay for 60 bucks. i think its pretty awesome
comes with full fob (some have case only), uncut blade & chip
Old Feb 16, 2012 | 11:40 PM
  #247
G35SedanGrn's Avatar
I really wish someone would make one of these for me :/
Old Feb 28, 2012 | 08:14 PM
  #248
cjb0009's Avatar
great mod
Old Mar 10, 2012 | 07:21 PM
  #249
G:Drive's Avatar
i bought the switchblade key off ebay for $15 and i really love it. one of the best mods you can do if you dont have the smart key.
Old Jun 30, 2012 | 01:43 AM
  #250
neo_anderson302's Avatar
My panic button isnt working. Is this normal?
Old Jun 30, 2012 | 02:54 AM
  #251
Originally Posted by OhhBWeezy
Umm, if anyone still does this.. I would definitely pay for one due to no soldering gun and a lack of patience lol
Its pretty easy you just need to get the Fcc: kbrtn001 remote
A solder gun is like $10 at pepboys, Double sided tape, and a dremel, I got one from habor freight for $7.
you only need to solder the battery piece. The wires can stay in under tension.
Old Jun 30, 2012 | 10:22 AM
  #252
OhhBWeezy's Avatar
Yeah, I know they tools to make it aren't all that expensive, just as I said before.. lack of patience is what's stopping me at this point.
Old Jul 2, 2012 | 05:22 PM
  #253
manolobleu's Avatar
So if my FCC number is different then I should match it up with one that is the same? The guy before me used a different one. Mine doesn't have a trunk release...
Old Jul 7, 2012 | 03:37 PM
  #254
You must be really lazy. For the look of the mod its the best bang for the buck. Cost $40 or less and takes 30mins. To each its own.
Old Jul 7, 2012 | 03:41 PM
  #255
So you have this one?
if so you can use it but you lose the truck feature. This remote is for the FX.
You really want this
