DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey
hey fellas,
I just got my infiniti fob. gonna do the swap tmr. I got mine from ebay (midwestkeyless) and the remote is in pretty clean condition. the uncut key they give you i think is aftermarket but the fob itself is oem product. some of the cheap fobs are not the oem but are aftermarket.
i'll post pictures if i can after.
so I got mine done 2 weeks back. It took me two tries.
First time I used a thicker copper wire which increased the thickness of the whole board. After wiring and sanding the tips to make it fit I realized the case will not properly fit due to its thickness.
I then gave up for that night and started over next morning.
This time I used wires that I separated from stranded (braided thinner gauge wires) wire so it will not add too much added thickness. I was worried it may be too thin but I found it was a lot easier to manipulate the thinner wires and put them through the holes in the board. Also the buttons felt better as the buttons could now travel all the way in.
So my advice is to anyone that are DIY try to steer away from thicker wires and try to find wires that are thinner. You can easily find stranded wires as they are cheaper than solid core. You will commonly find them in old computers. Don't worry about the wires being too thin as they will work no problem.
GL!
GL!
oh and another thing, I suggest getting the Key Fobs with already cut keys as they are more likely to be OEM. When I got my key fob I quickly realized the remote itself was OEM but the un-cut keys were aftermarket. You can tell this by the uneven silver coating on the top and ugly key colour (it's got bronze tint to it). This non-oem key doesn't fit nice and tight on the remote and you can tell it from a mile away.
sick sick mod i need this in my life, is using a cold solder a good idea as my soldering skilss are how do you say it Suck...
ultrablue60000k sent you a pm
bump
bump
