DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey
Old Jun 7, 2010 | 12:39 PM
  #166
hyeboy14's Avatar
help!
Does anyone have a url or ebay page of where i can get the exact smart key that parklife got so i wont have problems like the other guy with the buttons not matching up? or maybe the fcc ID? Thanks alote !
Old Jun 7, 2010 | 02:30 PM
  #167
Integi2a00's Avatar
Old Jun 7, 2010 | 03:39 PM
  #168
hyeboy14's Avatar
fcc numbr
do u know the fcc number? and was it easy to do ?
Old Jun 7, 2010 | 03:40 PM
  #169
Integi2a00's Avatar
the keys from midwestless are the ones you need... fairly easy a little bit of playing with the wires but i got it done
Old Jun 7, 2010 | 03:57 PM
  #170
hyeboy14's Avatar
Did you get yours used or brand-new, the only brand new one in there site is for a g35x sedan, the ones that say coupe are used, do u think it will make a difference?
Old Jun 7, 2010 | 04:00 PM
  #171
Integi2a00's Avatar
Old Jun 7, 2010 | 11:29 PM
  #172
hyeboy14's Avatar
one more question, when i am soldering the wire into the whole, do i solder it in the hole and leave it like that , or should i solder it on the round gold circle next to each hole on the back side of the chip. i cant tell by the pictures, thnx
Old Jun 8, 2010 | 04:19 PM
  #173
Integi2a00's Avatar
all i did was follow all instructions and follow it to the letter.... all i solder was the think that held the battery down
Old Jun 9, 2010 | 12:20 PM
  #174
hyeboy14's Avatar
i see, i thought i have to solder the wire. well when im putting the wire in the hole, this it have to be touching to the round gold circle next to to holes for it to work? or just the hole?
Old Jun 9, 2010 | 01:09 PM
  #175
Integi2a00's Avatar
yeah as long as the copper connections are good then your good to go. i stuck the copper wire in the hole and bent it on the backside and it was a good connection
Old Jun 12, 2010 | 02:49 AM
  #176
BuzzLightYear's Avatar
Just finished doing mine and putting it together and everything works. Only thing is that the sides of the new fob don't sit flush. I have a minor gap on both sides, like its too crammed in there. I saw someone earlier mentioning that they cut something. Anyone got any insight?
Old Jun 13, 2010 | 12:40 AM
  #177
hyeboy14's Avatar
one more question which im confused about, the "unlock" button has a extra blue line going thru indicating another wire right next to the red line if you look very closely . is that a mistake ? because it doesnt make any sense ....
Old Jun 13, 2010 | 01:07 AM
  #178
No need to run another one. It can use the same one.
Old Jun 13, 2010 | 12:02 PM
  #179
hyeboy14's Avatar
but do u see what im talking about in the illustration picture? the guy drew a 2nd blue line (small) for the unlock button. does that have a purpose or is it a mistake on his part? thnx
Old Jun 13, 2010 | 07:15 PM
  #180
It'll work with or without it. I did without it on mine and it works fine.
