DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 7 votes, 4.86 average.
Old Aug 21, 2008 | 10:30 PM
  #241
infinus's Avatar
I had the same problem, my RCA wires were white and black, my friend told me white was positive and it worked. As far as I can find on the internet: An inner wiretransmits the (+) positive audio signal while an outer braid transmits the (-) negative audio signal.
Old Aug 21, 2008 | 11:29 PM
  #242
Gilley's Avatar
That is correct. Different RCA cables may have different colored wires. The Monster Cable lines I used had black and red sleeves.
Old Aug 21, 2008 | 11:37 PM
  #243
JimmyYahoo's Avatar
Using a multimeter and a battery I now have a way to determine to which lead im sending the signal to. Where does the positive signal go? To the male nub or the female sheath part of the RCA?
Old Aug 21, 2008 | 11:43 PM
  #244
JimmyYahoo's Avatar
7356th Google hit has revealed the answer. Inner +, outer -.
Thanks all for the help.
Old Aug 22, 2008 | 12:46 AM
  #245
ConradoR's Avatar
I just finished this DIY... awesome! Thanks for all the guys who helped out with the little details along the 17 pages
Old Aug 23, 2008 | 08:32 PM
  #246
JimmyYahoo's Avatar
Yay
Old Aug 26, 2008 | 09:36 AM
  #247
S00NR1's Avatar
I am assuming that there is not a PAC adapter to do this install? When installing my amp and subs to my '01 Maxima with Bose the PAC adapter was fantastic and the sound was better than I was expecting. I am wondering with this particular modification if the sound will be at the same level as using an adapter at the HU?
Old Aug 26, 2008 | 01:54 PM
  #248
Gilley's Avatar
No, there is not adapter for the Bose amp. The only adapters are to mate an aftermarket radio to the Bose amp.
Old Aug 31, 2008 | 01:34 AM
  #249
vinflouen's Avatar
Whats up.
I got an Eclipse XA4200 powering 4 6.5 Eclipse's in the cabin. The max power rating on the 6.5's are 120. The amp runs at 125 per channel.
When I crank it I get the pop that I dont want to hear.
What gives?
Is this just tweaking the inputs on the amp?
I also have an XA1200 powering 2 Eclipses in a custom box.
So the bass is fine, just the cabin is an issue.
Do I need more powerful speakers in the cabin?
thanks
Old Sep 1, 2008 | 11:32 PM
  #250
vinflouen's Avatar
ok, so I got rid of the eclipse's in the door, and replaced them with infinity references, much better.
Some tweaking of the amp controls, and finally super sound that is quite honestly, too loud.
Do you guys know if the sell bass control *****? and if so, are they universal?
My amp has what looks like a phone input for the control.
Thanks
Old Sep 3, 2008 | 08:43 PM
  #251
S00NR1's Avatar
For those of you with a sedan -- here you go (credit to user 'acr' for this)
Originally Posted by acr
For those who are thinking of installing subs in their 05-06 sedan, here are the wires you need to tap into. I would've loved this info when I was doing my install, apparently it's not available anywhere on the forums. It was a huge ****ing pain in the *** to find out which wires need to be tapped since the majority of info out there is for the coupe. Hopefully this will make it easier for other sedan owners.
These wires are found under the rear deck on the driver's side. These are in the blue plug going into the BOSE amp. These are PRE-AMP wires, so you can just splice RCAs into it.
REAR LEFT+ Blue
REAR LEFT- Pink
REAR RIGHT+ Brown
REAR RIGHT- Yellow
This helped greatly.
Old Sep 4, 2008 | 06:48 PM
  #252
S00NR1's Avatar
Well, I thought I had everything just right -- when I turned the stereo on, I got this incessant whine from the speakers in the rear doors. Everything powers on correctly (amp), but this whine will last for about 10 seconds and then it shuts the radio off. The whine only occurs when the RCAs are plugged into the amp.
Any ideas?
Edit: Could this be an amplifier issue? I have an MTX Thunder 4202 amp. In the user manual, it states the Input as low level and "hi level w/smart engage". The RCA Output is stated as "Full Range Only". Should this read balanced instead?
Old Sep 4, 2008 | 07:56 PM
  #253
MikeGrote's Avatar
does that control **** just plug into the jl amp directly and will it work on the jl 250/1?
Old Sep 10, 2008 | 12:08 AM
  #254
Xet's Avatar
Xet
for the inner vs outer wire, is the inner wire the one that is smooth and the outer wire is the like regular copper wire???
also does anyone have any tips for splicing, I was splicing mine today and man infiniti doesnt give us any extra slack on the wires. I was trying to get some extra wire to create a bridge between the stock wires.
Old Sep 10, 2008 | 03:07 PM
  #255
paky786's Avatar
If I was adding one 10" sub, 6.5 components in the front and 6x9's in the rear shelf, with ONE 1x1500W amp.. Is it possible to do that? One pair of speakers power handles 50-100W and the other 50-120W.. so 220 Watts and get a subwoofer around 600W peak.. You think that would work? I have a HiFonics TXi1508D which like I said 1x1500 watt.......... AND STOCK-HU
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
