DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 7 votes, 4.86 average.
Old Sep 10, 2008 | 06:55 PM
  #256
Gilley's Avatar
^ That won't work at all.
Old Sep 10, 2008 | 07:17 PM
  #257
paky786's Avatar
Yeah, I'm just going to add two amps in there! :S
Old Sep 12, 2008 | 09:30 AM
  #258
infinus's Avatar
What the eff man this car is pissing me off, I just had a 3rd subwoofer go dead in this damn car, I've had 2 infinity's and an alpine type R all blow for no damn reason, its not like I crank it all that high I normally listen to it on like 17 or so, it works perfectly fine then in the middle of a song it just stops dead, its done that with all 3. My amp is fine no protect lights or anything and I'm not overpowering the woofer, I've had two blow in this box and another in a second box, could it be the amp? I also have SSV set on high, could that do anything?
Old Sep 12, 2008 | 09:34 AM
  #259
paky786's Avatar
Hmm, well we all know it can't be the car :P How many watts is the amp and how much are you putting the gain up to? Because thats how I blew up my effin JL 15" ((((((( stupid mistake
Old Sep 12, 2008 | 09:38 AM
  #260
infinus's Avatar
Yeah I know it cant be the car but its cursed or something cause one of the setups was from my old car and it worked perfectly in there, the new car killed it in a week.
The amp is 600 RMS at 2 ohms. Gain was like at 80-ish%
Old Sep 12, 2008 | 10:20 AM
  #261
paky786's Avatar
Hmmp... Be sure that you have correct wires or message gilley.. He's always a major help!
Old Sep 14, 2008 | 07:27 PM
  #262
JG35E's Avatar
Romoving BOSE Sub
Does anyone know how to remove the bose sub from the trunk so my new sub can get some more air displacement into the vehicle?
Old Sep 14, 2008 | 09:33 PM
  #263
paky786's Avatar
Here is the link! http://www.thegsquad.org/DIYS/Rear%2...%20removal.jpg
Old Sep 21, 2008 | 09:49 PM
  #264
mike_d's Avatar
so i ran my amp wires and hooked it up but got no power. how come?
pwer wire good
ground is what I suspect, but i removed paint and drilled into an area by the spare tire
remote is questionable(it came on the LOC) but that shouldnt matter until I actually get the amp to show power on
any suggestions
Old Sep 21, 2008 | 11:45 PM
  #265
Gilley's Avatar
Test to see if the amp turn on wire is getting power.
Old Sep 22, 2008 | 02:20 AM
  #266
mike_d's Avatar
pwer wire good
any suggestions
i am a dumb A$$. the LOC doesnt have a remote wire, it has a groun wire. What was I thinking, I hope I didnt mess anything up. I just though of it, I ahve to mess with it tomorow
Old Sep 22, 2008 | 03:51 AM
  #267
mike_d's Avatar
I decided to do it a few minutes ago... cut the ground/remote connection, im an ftard. Put the remote wire on B+ and WOW, it is way louder than it was in my old truck. It just a RF 8" in a little box made to fit under the front seat of a nissan titan a RF single channel amp.
So now I read through and 1 there is no blue connecter and 2 I read that the blue w/ grey dot or teal w/ grey dot is remote for bose amp. Neither of them worked, they are the thicker wires on the right connection prong.
Which wire is remote??? Anyone got a pic or diagram?
Old Sep 22, 2008 | 04:59 PM
  #268
paky786's Avatar
Originally Posted by Gilley
The wires going into the Bose amp are full range. The Bose amp separates the low frequencies and sends them to the 6x9's.
Here are the wire colors.
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
Gilley is awesome!
Old Sep 22, 2008 | 09:39 PM
  #269
vinflouen's Avatar
does anyone know how I can get my 2 eclipse amps to turn on when the radio is on?
Right now I get this hiss from the tweeters (stock) whenever the car is on, its really annoying.
The system sounds great. I have Infinity 6.5 in the door, and 2 12's Eclipse in the back, with 2 eclipse amps.
Any help is appreciated.
Old Sep 22, 2008 | 10:52 PM
  #270
Gilley's Avatar
^ The gain on your amp is turned up too high if you hear hiss.
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
