DIY: Add a sub to your Bose equipped G35 Coupe
Rating: Thread Rating: 7 votes, 4.86 average.
Old Jul 4, 2011 | 01:50 PM
  #526
qbanboy's Avatar
Originally Posted by eurodre
then you're not looking at the right wire pack, this one is right under the amp rack
NO i`m talking about the wires that goes directly to the speakers not to the amp, my bad i didn't specify...the two plugs that come with the factory bose speakers they have this color wires...i splice them but dont know which is the + and -
Old Jul 4, 2011 | 01:55 PM
  #527
eurodre's Avatar
oh i know what you mean, yeah sorry hope someone can pinpoint that for you, at the end of the day you can just temp bind tie them together and do a trial and error, got a 50/50 chance if you hear sound it worked, if not switch to the other one
Old Jul 4, 2011 | 01:58 PM
  #528
qbanboy's Avatar
thats the thing either way a connect them still give me signal ,i have a crossover on my 6x9 dont know if that is why? so both cables work as negative and positive....WTF?
Old Jul 4, 2011 | 02:00 PM
  #529
eurodre's Avatar
well that's weird maybe someone can chime in on that one
Old Sep 17, 2011 | 03:39 PM
  #530
jiggawuah's Avatar
does anyone have a good diy for how to remove the 6x9s? I have searched and it says to remove rear seats. and side panels and finally the trim around the speaker grills, but it'd be nice to actually have instructions? thanks!
Old Sep 17, 2011 | 03:55 PM
  #531
paky786's Avatar
Originally Posted by drsifu1
to remove 6x9 in coupe:
1- remove rear seat bottom by pulling hard straight up
2- remove rear back rest by removing 2 nuts (12 or 14 mm)
3- remove both rear qtr panels by pulling it to remove the clips
4- remove driver and passenger seatbelts
5- remove both trim panels
6- if applicable, remove rear brake light
7- remove rear parcel shelf
8- gain access to the 6x9
this gives you a general idea on how to get to them. lot more specifics, but it should be fairly intuitive once u get started.
Here's what I found on a search result. I tried to find the exact same DIY I followed but my attempts failed. Hopefully this helps!
Old Sep 17, 2011 | 07:49 PM
  #532
jiggawuah's Avatar
thanks alot! i just finished putting everything back. everything was easy except putting the panels back without bending the pokey clip thingies..
Old Sep 18, 2011 | 08:35 AM
  #533
paky786's Avatar
Lol, I bet..those lil ones are very easy to break as well
Old Oct 10, 2011 | 11:51 AM
  #534
Arrchie's Avatar
Trying to read as much of this thread as possible but want to make sure on connection from stock amp to rcas. Now i reed you can use rcas and pretty much cut them but could u also use a line output converter? then just connect the rcas from the converter to the amp. It seems too simple just to connect these 5 wires, power, etc and then your good to go. Just trying to save money and do this myself (also have stock headunit)
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
Old Oct 12, 2011 | 02:21 AM
  #535
OSKIRE's Avatar
I've subscribed to this since 2006 and finally might try it. What's a good amp and sub to get nowadays?
I just need a decent sub and amp...still doing things on a budget! THANKS!
Old Oct 12, 2011 | 01:14 PM
  #536
LakeShore_Slate's Avatar
Sames here
Old Nov 3, 2011 | 06:10 PM
  #537
G35 Dream's Avatar
Just did everything on here to the T and when I turn the radio on I get a loud ring coming from the rear drivers side speaker (not the 6x9) for about 30 sec and then it stops and I get nothing till I shut it off and turn it back on. Any suggestions?
Old Nov 10, 2011 | 03:55 PM
  #538
beezee's Avatar
I have read through the entire thread 2 times and I say thanks for such a helpfull DIY and all the added inputs.
I was looking for an answer to a specific question but did not find a clear answer and how to. There were 2 other posts that asked the same question but did not get a clear answer as well.
This thread is about adding a Sub to the Bose through an added Amp. What if in addition to this you want to completely eliminate the Bose Amp and install a second 2 or 4 channel amp for the speakers while keeping the STOCK headunit? (2 channel if only using the front speakers). If it is possible, how will the second Amp be connected?.
I plan on getting an after market HU in the future but for now I want to hold on to the stock appearance.
Thanks for any inputs
Old Nov 10, 2011 | 05:10 PM
  #539
Wrathernaut's Avatar
Gentle Manne of Leisure
That topic is covered in another sticky'd thread:
https://g35driver.com/forums/audio-v...-stock-hu.html
Basically, you need an amp that handles differential-balanced signals and you need to run your own power and ground wires, otherwise you can use the stock speaker wiring to and from the bose amp location.
Old Nov 10, 2011 | 07:43 PM
  #540
beezee's Avatar
Thanks. I found everything in that thread.
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
