stock bose system not working properly
Old Nov 14, 2007 | 12:42 PM
JJKK's Avatar
I have a 04 coupe with bose system.
This happens 3 times now....
the first time I brought it in was for left side of speakers aren't working properly. (sometime on, sometimes off). They replaced the audio head unit.
but after about 1 month.... one morning... same thing happen again, and this time it's even worse, none of the speakers were working at all.... I can still see the letters from the small screen, but just nothing coming out of the speakers... and again... it sometime works... sometimes not.....
so, I brought the car in again for same issue, and they say they will replace the head unit again...
I had the car back last nite (it was working perfectly fine there), but this morning when I start the car and turn on the radio..... again.... no sound from any of the speakers.....
does anyone have this kinda problem?? I told them it might has something to do with the wires or the speakers..... but the SC said it's the head unit's problem....
Please help me.
thanks.
PS. i tried banging it hard on the side of the headunit...
but still no...
Old Nov 16, 2007 | 12:12 PM
Phoneix's Avatar
I have an 03 G35. DO you know which cable or cables going into the amp is the power?
I had battery issues so I disconnected the amp and that worked. Now I'm going to re-wire the power source, so the amp shuts off when the car is off.
Old Nov 17, 2007 | 12:11 AM
TexasVoodoo's Avatar
I have the exact problem. No sound from stereo or Nav. One thing I know for me is that it only does it in cold weather. If its cold outside then my speakers wont kick on until I have the inside of the car blazing with heat if they come on at all. If it's say, above 75 outside, it never misses a beat. When I start the car in the mornings from the garage it works great. When its outdoors for work and its say, below 65, I'm screwed.. Dealership told me they have never heard of it. Just bring it in and they'll charge me 85 bucks just to look into it.. Not thanks... Yet anyway.
Old Nov 17, 2007 | 12:45 AM
318g35's Avatar
im having the same problem with mine.. idunno whats wrong with it. it comes on and off. everytime i hit a bump it goes off. but it comes back on. both allways work when i the radio is on but when a cd is playin its gayy
Old Nov 17, 2007 | 10:26 PM
John Henry's Avatar
Same thing here with an 04 Coupe. I plan to get it replaced, still under warranty. From what I've read, some people get lucky after 1st replace, others are like JJKK and do it a few times. I wonder what the deal with that is...
Old Nov 25, 2007 | 03:08 AM
JJKK's Avatar
turns out it's the amp problem.
they replaced it with a new one...
it's been 1 week now, and everything seems working fine finally
Old Nov 25, 2007 | 03:10 AM
JJKK's Avatar
mine was exactly the same, every morning when it's 61~63 outside, no sound for sure
Old Nov 25, 2007 | 09:55 AM
Gilley's Avatar
Thanks for the follow up post. Maybe that will help others with that same issue.
Old Nov 25, 2007 | 10:33 AM
plm7878's Avatar
I just bought my 04 sedan I hope I don't have that problem..
Old Nov 25, 2007 | 10:23 PM
BALLINassG35's Avatar
mine happened today too. and it was 30 degrees out
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
joedaddy1
Jul 28, 2015 02:58 PM
BlackGee35
Jul 21, 2015 07:24 PM
