Check Engine Light After Install
Old Feb 20, 2008 | 01:29 AM
1trueG's Avatar
Service Engine Light After Install
Tonight I installed an amplifier along with a subwoofer in my g35 coupe. I installed the amp with the speaker wire to rca connector from JL Audio. The sub and amp are working perfectly but after reconnecting my battery, I noticed that the service engine light has came on. I was careful when I installed everything and Im not sure what it could be. The only thing I can think of is water getting in the engine bay because it is raining and I had my hood open and the car wasn't fully in my garage. Any suggestions? I disconnected the negative and the car is parked in the garage so I am going to see if it goes away by tomorrow morning.
Old Feb 20, 2008 | 01:32 AM
THE_SCHROED's Avatar
Hmmm... Never heard of this before. I don't know why water would make a difference.
1trueG's Avatar
I dunno either because if any water got in, it was only a little bit of rain...
Old Feb 20, 2008 | 02:11 AM
Sponger's Avatar
6MT Brembo Coupe
It's possible that water got in through the main grommet you punched for the battery cable for the amp. I put a bead of silicone around the wire to prevent water from seeping through.
Old Feb 20, 2008 | 02:22 AM
1trueG's Avatar
I actually sealed it with silicone as well. But if water did get through there, how would that throw the Check engine light?
Old Feb 20, 2008 | 02:42 AM
Sponger's Avatar
6MT Brembo Coupe
That grommet has a main harness going through it. Correct me if I'm wrong, but isn't the ECU located under the dash on the passenger side?
Old Feb 20, 2008 | 02:46 AM
1trueG's Avatar
Im not sure if it is or not. If so, that can be another possibility.
Old Feb 20, 2008 | 12:46 PM
Scrooge's Avatar
Why don't you just get the code check first.
Old Feb 20, 2008 | 12:55 PM
1trueG's Avatar
^ Yea thats what Im gonna end up doing...This morning I reconnected the negative and when I started it up, the light went away. I stopped to put gas, then started it back up and it came back on.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
