How To Install A Sub In A G sedan Using Stock Bose System
Old Apr 30, 2010 | 01:28 AM
  #61
SCIONMIKE's Avatar
wow im just reading here and now im finding a reason to use some of the amps i have here laying around. heheh. just tryin to find sub size and any recomendations since i think i need a freeair sub right?
Old May 10, 2010 | 03:27 AM
  #62
or_G's Avatar
anyone do this yet? how good does it sound?
Old May 10, 2010 | 03:29 AM
  #63
kennymo's Avatar
if you want to put the sub in the stock location then yes you will need a freeair sub.
Old May 10, 2010 | 03:30 AM
  #64
kennymo's Avatar
good thoughts can i replac4e the stock sub? whats the size?
stock sub is an 8
Old May 23, 2010 | 10:52 PM
  #65
Mess817's Avatar
Hi guys, just so I'm clear. (not much knowledge on systems)
I can hook up an amp and sub to work with my factory bose system? (06 sedan)
I have a Phoenix Gold Tantrum 600.4 and a Treo 10" sub in a custom ported box
Old May 23, 2010 | 11:19 PM
  #66
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes.
That's why the title and subject of this thread is "How to install a Sub In a G sedan using stock Bose System." instead of "You can't install a sub in a G sedan if you have a stock Bose system."
Old May 24, 2010 | 12:23 AM
  #67
MotoCARR's Avatar
G35 Sedan
^lol
mess817, yes you'll be fine in your '06 sedan. I've done a few and it's a very similar process.
Old Jul 14, 2010 | 08:29 PM
  #68
psychomotif's Avatar
Quick stock amp with aftermarket sub question.
I have a 2003 6mt coupe.
I have a spare 12 inch sub from my last car which i want to connect to the stock amp, since the factory subs do not produce enough bass.
My plan is to disconnect the wires from the factory subs and connect it to my aftermarket sub without tampering with the amp.
Please let me me know if that is possible, if not then what needs to be done.
Old Jul 14, 2010 | 08:54 PM
  #69
MotoCARR's Avatar
G35 Sedan
Stock amp won't be able to power it. You will need an aftermarket amp.
Old Jul 15, 2010 | 01:59 AM
  #70
#1 Your plan is bad. What were you going to do, try and power a 12" subwoofer off what was powering a single 6x9" or try bridging both 6x9's power? Do you have any concept of what RMS, bridging and Ohms are?
#2 You can't bridge the bose amp.
#3 Even if you did, it still wouldn't be enough to get any sort of quality or power out of it.
#4 Don't just put crap you having laying around in your car because you have it. Seriously. I have extra tires in my garage, does that mean I should bolt them to my trunk?
Leave that sub out of the car, save up some money and don't do things 1/4 assed.
Old Aug 3, 2010 | 08:38 PM
  #71
romeo007's Avatar
hi, i have a question.
can u add a capacitor? would you recommend to do that?
thank you
Old Aug 3, 2010 | 08:41 PM
  #72
djfarhan's Avatar
^ yeah u can and it depends on ur how strong ur amp is
Old Aug 3, 2010 | 10:07 PM
  #73
The Stimulation's Avatar
No purpose in adding a cap. Simplest way to put it...it's a band aid. If you're cut deep, are you going to use a bandaid? Nope. If you don't have any cuts or anything, would you use a bandaid? Nope. Caps take too long to charge and discharge at a much faster rate. If you're electrical is up to par, no need for it..if it isn't, it will only hurt it.
Old Aug 4, 2010 | 02:00 AM
  #74
^ +1
Capacitors = worthless, but they look cool!
More powerful amp is the only real fix.
Old Aug 4, 2010 | 04:56 PM
  #75
MotoCARR's Avatar
G35 Sedan
^^This^^
I have found that 9/10 times you get better results performing "The Big Three" than slapping on a cap if the electrical system is a touch under par for the stereo in the car.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
