How To Install A Sub In A G sedan Using Stock Bose System
Rating: Thread Rating: 3 votes, 5.00 average.
Old Aug 4, 2010 | 06:22 PM
  #76
The Stimulation's Avatar
Originally Posted by w8lifter21
^^This^^
I have found that 9/10 times you get better results performing "The Big Three" than slapping on a cap if the electrical system is a touch under par for the stereo in the car.
^^This^^
Lol. So true though
Old Aug 4, 2010 | 07:35 PM
  #77
gh0st's Avatar
caps suck. i hate messing with them. they always spark and scare me lol
Old Aug 5, 2010 | 07:22 PM
  #78
MotoCARR's Avatar
G35 Sedan
Especially when you are messing with one under a seat and your watch happens to touch both terminals causing a few links to weld to each other rendering the watch unremovable
Old Aug 13, 2010 | 01:36 PM
  #79
g35>350z.werd's Avatar
i have 2 12" alpine type e's. recommended amp?
Old Aug 13, 2010 | 01:55 PM
  #80
Wrathernaut's Avatar
Gentle Manne of Leisure
Since they're budget subs, not real SQ or SPL, you won't hear the difference with a higher quality amp, so just do something like this:
http://www.woofersetc.com/p7757/STL1...-Amplifier.htm
Your subs are the 4 ohm version, right? So you'll wire them in parallel to show the amp a 2 ohm load, so you'll give them each 250 watts to play with, which should give you enough thump to enjoy your rap or pop music just fine.
If you wanted to enjoy some really high-quality bass in classic rock, rock, or classical, you got the wrong subs. Alpine Type-R's are a much better (and still pretty cheap) choice if you intended to listen to that kind of music.
Old Aug 13, 2010 | 07:05 PM
  #81
nah rap haha
Old Aug 13, 2010 | 08:16 PM
  #82
Well, enjoy then, rap's really forgiving with cheap subs, I suppose that's a redeeming feature?
Old Aug 22, 2010 | 08:04 PM
  #83
romeo007's Avatar
hi, im a newbie and have a question.
For Those Who Are Running The Same Setup:
4080 Box, Jl 500.1, And 10w6 What Settings Do You Guys Have?
Output mode =
Filter slope =
filter freq =
filter mode =
infrasonic filter =
infrasonic freq =
Q =
Center Freq =
Boosts =
input voltage =
Thanks For Any Reply
Old Aug 23, 2010 | 02:27 AM
  #84
A lot of these will depend on what settings your headunit is set to, particularly the input voltage, boosts.
Sorry, I never checked what I'd settled on before I left.
Old Aug 26, 2010 | 01:54 AM
  #85
romeo007's Avatar
Output mode =
Filter slope =
filter freq =
filter mode =
infrasonic filter =
infrasonic freq =
Q =
Center Freq =
Boosts =
input voltage =
can someone help me out? i have no idea wat to do.
thank you
Old Aug 27, 2010 | 12:40 PM
  #86
Most of these are covered in the install manual, but again, most are greatly affected by the rest of your system beyond the subwoofer itself.
Old Sep 6, 2010 | 11:25 AM
  #87
marimba's Avatar
so i have been having problems with my sub/amp. i have a 12" Memphis PR with a 500W PR1 amp connected to the stock sub and amp. Lately the 12" just stops working. i took a look at the amp and its not going into "protect" mode (overheating) and all the cables are connected right. sometimes i can hear (i believe) the stock sub "crackle", like when you have a bad/broken speaker. i have no idea if the stock equipment is bad and causing interference with the aftermarket stuff. i would appreciate any help since i dont know whats going on...
Old Oct 16, 2010 | 07:29 PM
  #88
EDW1NK's Avatar
Will I be able to use the factory sub by doing this?
Old Oct 17, 2010 | 03:42 AM
  #89
Don't expect any helpful response when you post such a vague question to a thread with over 6 pages.
Old Oct 17, 2010 | 04:12 AM
  #90
EDW1NK's Avatar
I just posted in your other thread. I installed a f700bt on my sedan w/ Bose, and now my sub doesn't work anymore. I was just wondering if it was normal, and if installing a separate amp will make it work again.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
