Is dynamat in the trunk worth it?
Old Jun 14, 2004 | 07:19 PM
afr0puff's Avatar
Supa Dupa Moderator
I've done the rear wheel wells and I'm just wondering if it's worth it to do the entire trunk? There is so much material between the trunk and the front passengers, it makes me wonder what difference it will make. I don't have spoiler that can be rattled, so what's the point? If there is a case for sound deadening the trunk on the coupe, which sections would be worth it?
http://www.anythingbox.net
Old Jun 15, 2004 | 11:15 AM
al503's Avatar
Re: Is dynamat in the trunk worth it?
I would wait until after you get your stuff in and then listen for the trouble spots. The coupe is a lot better than the sedan in terms of trunk rattles from a sub.
Old Jun 15, 2004 | 11:44 AM
djrobx's Avatar
Have you gotten outside the car and listened to rattles *outside* when the sub is going? I'm hoping some dynamat in the trunk will reduce that some.
-- Rob
Old Jun 16, 2004 | 03:17 AM
bamadog's Avatar
Black 2004 G35 6MT, chrome wheels, black, still pristine
I got outside my car a couple of days ago just to actually SEE the trunk move when the bass was thumping pretty hard, and it does move a little, but even a little more on the top part of the rear bumper. I have a coupe w/spoiler, but there wasn't any major "rattles" - mainly just movement vibrations. I have a trunk dynamat kit already, but I have yet to install it - will probably do that soon.
The Bamadog
BAMADOG.COM
2004 G35 Coupe - Black/Black 6MT - Chrome 7-Spoke Wheels - Aero Kit & Package w/spoiler - Tint - Alpine System - Body Side Molding
Old Jun 16, 2004 | 11:01 AM
fluffydot's Avatar
afro, do you have pics of your dynamating the wheel wells?
how exactly did you do that?
that is probably the most important place to dynamat against road noise...
Old Jun 16, 2004 | 11:33 AM
afr0puff's Avatar
Supa Dupa Moderator
It's the same as what others have done. I just put two layers on the wheel wells and one layer everywhere else. Here is what 6MTHavoc has done:
As far as the wheel wells go in the trunk of the coupe, you can't dynamat the right wheel well in the trunk, only the left one. For the right side, your best bet is just to cover the boxy area around the wheel well, which I think is the fuel pump/system.
Old Jun 16, 2004 | 01:30 PM
djrobx's Avatar
<hr></blockquote>Wow, really? Mine makes a ton of buzzing and other assorted noises particularly from the underside of the car. You can't really hear it inside the car. My spoiler doesn't cause problems, though.
Old Jun 16, 2004 | 05:10 PM
g35mt's Avatar
afr0puff,
do you see those screws on the side. I opened up those and dynomated the side last weekend. It's a pain but well worth it. I did the rear well just like you. Also i did the rear passenger seat too.
This weekend i will do the trunk. What i really want to finish doing is under the driver and passenger seat. The last portion will be the top where the sunroof is at.
g35mt
Old Jun 21, 2004 | 03:46 PM
afr0puff's Avatar
Supa Dupa Moderator
God damn! I can't hear my exhaust anymore! But wow, the stuff sure does work.
ara777
Oct 25, 2017 01:45 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
Visionnn
Oct 3, 2015 05:16 AM
