USA Spec Pa15-NIS
Old Mar 23, 2011 | 12:35 AM
  #271
jerryG45's Avatar
Sometimes when I plug mine in, it will play then disconnect, in which case I would need to remove the plug and then plug back in and it tends to reset to the first song on the Iphone. Very irritating as I would like for it to continue on the playlist but then again I would like for it to work without having to continously unplug and plug in.
Old Apr 3, 2011 | 02:51 PM
  #272
rayzah's Avatar
I think I done everything correct, but it is not working. I have the PA15 infi and im installing it on a 04 G35 W/bose and the /sat button. I hooked everything up but when I press the SAT button all I get is a messege that says no sat, it's not even showing anything on my ipod, what could possibly be the problem?
Old Apr 3, 2011 | 11:27 PM
  #273
BabyH21's Avatar
Did you ground it properly? All the switches in their initial position? Try clicking your radio button on the steering wheel to see if you have "CD CHG."
Call up tech support and see if they have a solution as well!
Old Apr 6, 2011 | 06:17 AM
  #274
rayzah's Avatar
Yea that fixed it, I did not properly ground it. Thanks
Old Apr 6, 2011 | 09:48 AM
  #275
w4kj4k's Avatar
For anyone that has the NIS version of the PA15, where did you guys ground the wire at? It is extremely short and i can NOT find any bare metal anywhere behind the whole head unit when i take it out.
Thanks!
Old Apr 6, 2011 | 09:53 AM
  #276
BabyH21's Avatar
Originally Posted by w4kj4k
^ Where did you end up grounding it? The wire is super short and i can NOT find any bare metal to ground it to in the area.
Thanks!
I did mine right on the Bose amplifier. You should be able to just sandwich the grounding wire between one of the screws and the metal housing.
Old Apr 6, 2011 | 09:54 AM
  #277
w4kj4k's Avatar
^ ahh yeh i had to edit my post because i realized yours was the INF and was installed from the trunk, which probably has a bunch of bare metal exposed compared to behind the head unit where freaking everything is plastic :[
Old Apr 6, 2011 | 09:57 AM
  #278
BabyH21's Avatar
Thanks!
Woops sorry! I didn't see that you used the NIS version.. I think the grounding wire can be pulled off the main cable a little more to give you some length. Can you find any screws you can sandwich the grounding piece to?
Old Apr 6, 2011 | 10:01 AM
  #279
w4kj4k's Avatar
I'll have to look harder next time when i decide not to be lazy and pull my headunit out again. My Pa15 doesnt even work anymore :[ I wonder if not having a ground COMPLETELY makes it not work?
Thanks for the help!
Old Apr 6, 2011 | 10:14 AM
  #280
flyinb501's Avatar
I've had my PA5-NIS for about 6 months now, and I have to say that I am very disappointed with the sound. It is not crystal clear, and almost staticky at times. Also, has anyone had troubles with the aux port? Mine does not seem to work. Do you need to change the dip switch settings to use the aux port?
Old Apr 6, 2011 | 10:16 AM
  #281
petesg35's Avatar
Are you guys setting the dip on the pa15 unit?
Old Apr 6, 2011 | 10:17 AM
  #282
petesg35's Avatar
I believe you do, look at your manual that came with the unit. I had my for a while and no problems at all. I have a 07 coupe.
Old Apr 6, 2011 | 10:29 AM
  #283
flyinb501's Avatar
I set mine according to what the technician told me. I believe I have 1, and 3 on, the other two are off.
Old Apr 7, 2011 | 03:42 PM
  #284
flyinb501's Avatar
Alright I got it figured out. I had to turn off dip switch 1. Now I am able to use the aux port or the Ipod.
I am still disappointed in the sound quality though. I think it may have gotten worse over time. Could this be from a loose ground? I wonder if it came loose... I really don't feel like taking all that **** apart again.
Old Apr 7, 2011 | 03:48 PM
  #285
norton03's Avatar
I've read alot of these pages and searched, so if this has already been asked, sorry.
Does anybody have a DIY w/ photos for an '07? Alot of the convos on iPod integration seems to be centered on older G's. I'd like to add the USA Spec to my vehicle, but I have no idea where the connections are made. If there's no DIY, at least a few pointers would be great..
It's an 07 G35 Sedan, W/ Sat & Bose, no nav.
Thanks..
