Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
#2073
I have read all pertinent posts and reviewed youtube’s on the radio removal/repair/reinstall and Double Din aftermarket install. My 03, G35, radio and DVD player work well. Occasionally my AC turns on and locks up on its own but rarely if I keep it on all the time.
I prefer original stock look and audio system but am trying to get ahead of any possibly worsening problem.
I am buying a new DD JDM OEM dash housing/cover (kit) and Kenwood DDX6904S. Evidently the JDM nor radio come with any radio mounting brackets. Has anyone found these mounting brackets or info on how to fabricate them?
Is the Scosche trim piece the best/only way to go to achieve a “factory installed” look for the DD radio with JDM OEM housing/cover (kit)?
Evidently, this radio comes with an antenna adapter. To get good standard FM reception do I need to add an antenna amplifier, if so any recommendations?
Thank you in advance for any help on my questions.
#2075
If you got an antenna adapter, it's part of a package deal from your seller, that radio needs the antenna adapter listed in the parts list in the first post. You don't need an antenna amplifier. If you did, again... it would be in the first post.
sybertel (04-10-2018)
#2076
DD Install Update
Found that the Kenwood DDX 6704S does not fit in the JDM OEM DD dash cover. It is just 1/16 of an inch to wide as other Kenwoods seem to be. Mounting it flush seems to require filing down the dash cover or the radio face plate. Neither seems to be a good solution. The included Kenwood trim cover would hide most of this but is not particularly appealing. Does anyone have a suggestion to resolve this or it the Scosche trim piece a good way to get an OEM install appearance?
Thank you in advance for any suggestions,experience, or pics showing how this was resolved.
#2077
DD Install Update
sybertel (04-14-2018)
#2078
DD Install Update
#2079
![Smile](https://g35driver.com/forums/images/icons/icon7.gif)
Looking at the solutions provided above, I like the look of the black Kenwood trim plate placed behind the JDM OEM dash cover. It looks a bit recessed but there are no gaps when centered. Plus the black Kenwood trim plate does not stick out like a sore thumb as it does when mounted on top of the JDM DD dash cover. Radio and KW trim actually slip in OK behind the JDM DD dash cover w/o any modifications (application of mounting brackets not verified) .
Only question remains is will the unit still fit depth wise as that makes the unit about 6.75 inches deep (adds about ½ inch more depth)?
Thank you to everyone that has been kind enough to reply. This question is probably more difficult to answer but I would appreciate any advise before attempting some mods that are irreparable.
#2080
![](https://cimg8.ibsrv.net/gimg/g35driver.com-vbulletin/2000x1504/img_4652_0e5e3f45a8de9091298dd4f287e5bdf154d4f46a.jpg)
There is plenty of space behind the head unit. U could probably push it all the way until it falls in if u really wanted to. Here is mine mounted on top of the JDM trim. I did have to drill new holes into the mounting bracket to keep the angle of the screen to sit flush with the trim ring. I think it looks good.
![](https://cimg9.ibsrv.net/gimg/g35driver.com-vbulletin/2000x1504/img_4652_2ca3fc343f648702f8928cb35e7abb8e42a730fe.jpg)
![](https://cimg2.ibsrv.net/gimg/g35driver.com-vbulletin/2000x1504/img_4653_8206e3ba29c8bd8de3eadc204fb336eb90466ad6.jpg)
![](https://cimg6.ibsrv.net/gimg/g35driver.com-vbulletin/2000x1504/img_4654_d7cc3101e038d3bc88f6e69c945b2ab0d38dd2c4.jpg)
![](https://cimg8.ibsrv.net/gimg/g35driver.com-vbulletin/2000x1504/img_4655_c80da0a5e28a36c2919f35bc8ec24cdeddf55c1b.jpg)
sybertel (04-15-2018)
#2081
Nice looking install. Thank you so much for the helpful info and pic. Looks like the new Kenwood DDX 6904s unit will fit w/suggested mods. It has quite a few advantages over the stock unit. I like the idea of a backup camera.
BTW: With 94K on my 03-6MT I am having the front bumper and front wheels repainted to remove any rock chips/scratches. This will complete its front end restore to look like new plus new grill and windshield installed. I would like to get at least 5 more years driving it as I can not find another car I like to drive as much.
#2082
#2084
#2085
Lay the Metra trim on the floor, facing up. Grab your head unit and insert the rear end first. Might take a bit of pushing and wiggling...but it should go in.
Might also make it easier if you do it on a soft surface, like some grass. Thats how I did it.
