Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Rating: Thread Rating: 31 votes, 5.00 average.
Old Dec 2, 2011 | 08:40 PM
  #646
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by g3fly
Yo is there a reverse lamp wire up front some where? for the rear view camera signal wire to tap into. Im sure I once read a post Wrathernaut saying its a purple wire but I can't find the post so I wanna double check. I'm not tryna run another wire from the rear of the car to the deck. Also you guys think its safe for me to get the 12v for the camera from my amps distributor block?
Thanks
That should be fine for drawing the power.
I don't know the exact wire up front, I've never put a rear camera in so never had the need to look it up.
Old Dec 5, 2011 | 01:38 PM
  #647
DaveB's Avatar
Getting ready to do my aftermarket DD swap into my 03 G35 sedan with Bose. My JDM DD kit should be here soon.
I'm still on the fence about getting the steering wheel controller part because cutting OEM wires and such. The car will be sold in June/July when the Subaru BRZ comes out. I'll likely pull everything and put the Bose back into. The fewer parts, the better I'm thinking.
Questions:
1) Can I use the OEM headunit mounting bracket? I'm getting a DD headunit.
2) Is the DD trim piece/surround definitely needed or should I wait until I get my headunit and test fit into the JDM DD finisher?
Old Dec 5, 2011 | 06:31 PM
  #648
Questions:
1) Yes, if you needed to buy something else, it'd be on the shopping list.
2) It'll leave a gap with most units if you don't get the trim, but if you are getting rid of the car, don't bother.
Old Dec 9, 2011 | 02:06 AM
  #649
AARONHL's Avatar
Is there any soldering needed with the PAC ROEM-NIS2? Are there any installations instructions for that?
EDIT: This picture answered my question. I'm glad I don't have to hack into the factory wires. That end is plug and play.
Old Dec 9, 2011 | 08:35 AM
  #650
You'll want to solder it to the new headunit's harness, but other than that, it doesn't require cutting the factory harness. The steering wheel controls, however, still need to be tapped into the factory wiring.
Old Dec 9, 2011 | 01:06 PM
  #651
AARONHL's Avatar
Thanks!
I saw in another link a member used the white plug from his stock headunit to make a plug and play harness for the Metra Axxess ASWC. Once I make the harness where does that white plug plug into?
Wondering if there is a picture of that?
Old Dec 9, 2011 | 06:35 PM
  #652
Thanks!
Well, if you remove the harness from your stock headunit, it plugs right back into the same harness that was plugged into it before. None of the harnesses back there are interchangeable, so it's pretty much idiot-proof if it's put together right.
Old Dec 10, 2011 | 01:46 PM
  #653
AARONHL's Avatar
OK, thanks! That makes sense..
Old Dec 19, 2011 | 10:17 PM
  #654
Aztec's Avatar
so if i have a bose, but i dont want to use the bose amp, i use this adapter Metra 70-7550 ?
or do i still use this PAC ROEM-NIS2 ?
Old Dec 23, 2011 | 08:32 PM
  #655
dukehotty's Avatar
Thanks Wrathernaut!
At the Wrathernaut's for trimming!
Thanks again for all the pointers and suggestions!
Old Dec 27, 2011 | 01:06 AM
  #656
SAMzG35's Avatar
G35
is "Bythabay's DIY Video" still working? i tried on 3 different computers and still cant get it to work!
keeps on saying "Please use Internet Explorer to view this video or download the latest Firefox Flash Plugin: Adobe Flash Player" even though i am using IE and also tried it with google chrome
any ideas?
Old Dec 27, 2011 | 01:27 PM
  #657
any ideas?
Works great on mine, win7, firefox 8, flash 11.
Old Dec 28, 2011 | 04:07 PM
  #658
Project's Avatar
cant get my unit to even turn on...looks like its going to be a long night
Old Jan 1, 2012 | 07:26 PM
  #659
AARONHL's Avatar
Wondering if anyone can explain what I need to buy and/or do to be able to play DVD when driving on Pioneer 4300? I understand it's not as easy as grounding the e-brake wire and there is a relay needed. Anyone have a wiring diagram??
Old Jan 1, 2012 | 09:22 PM
  #660
It's the same bypass as 99.9% of the radios out there, just check youtube.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
