Is 4ga Power and Ground ok for 1100w rms?
Old Jan 13, 2011 | 07:21 PM
Spitfire91104's Avatar
Still dont know if im swapping out my 4.100 to a different amp or just replacing it and hoping for the best. I am also going to be running my 1.600 to a sub. Would my 4ga power which i have already ran be sufficient for these 2 very efficient class d amps? Its a run from the battery to the back part of the trunk. Thanks guys!
Old Jan 14, 2011 | 01:25 AM
Majiks's Avatar
i would use something thicker on my old car i was running 2300 watts and i used a 0/1 guage for u id prob go with something along 1 or 2 guage 4 is a little thin IMO
Old Jan 14, 2011 | 03:50 AM
The Stimulation's Avatar
Dunno what amp you're talking about but I'm guessing an Alpine PDX. The 1.600 is a 600w amp so 4 gauge will be fine. Easiest way to tell is by the power inputs on the amp. They'll only accept up to a certain size. Manufacturers know what size wiring is needed so if it's got an opening for a 4 awg, a 1/0 is not necessary.
Old Jan 14, 2011 | 04:11 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
For 1100w RMS, I'd go with something thicker, since you'll end up with about 12 foot of wire, and at that distance, 4 gauge is only good for about 800w.
http://www.the12volt.com/info/recwirsz.asp
Old Jan 14, 2011 | 08:23 AM
Dang. When i looked at 12v i read that those calculations were with amps that have approx 50% efficiency while my pdx's are supposed to have 80>. Now i gotta rewire power but meh. I hope knu koncepts has some in stock now. Thanks guys!
Old Jan 15, 2011 | 10:13 PM
blazeplacid's Avatar
wire is about current not watts
I think 4 ga will be ok
im running 1500 rms on 4 ga from the battery to the trunk and its fine
Old Jan 16, 2011 | 04:49 PM
LiquidClen's Avatar
1/0
Old Jan 16, 2011 | 05:18 PM
Yeah im just gunna buy 20ft of 1/0 of knukoncepts and a new distribution block. My lights are dimming so im prolly gunna get a grounding kit and new high out alternator.
Old Jan 16, 2011 | 06:07 PM
eggyhustles's Avatar
Run 0 from batt to distro, and 4 to each amp
Big battery would help too..no need for an alt
Old Jan 16, 2011 | 08:50 PM
Well I never play the stereo with the car off so a new battery isnt needed as much other things.
Old Jan 16, 2011 | 09:26 PM
That's not the reason for a bigger battery. How do you think your amplifier gets it's power? If it's not supplying enough, other areas of the car will hinder, example: your headlights dimming.
Old Jan 17, 2011 | 09:51 PM
Been looking at the Kinetik Batteries. Would the hc1800 be ok? Says it is for 1800w but i think thats with everything else in the car. I am running a 600w rms mono amp and going to be running a 480w rms 4ch amp. This new battery has 3 times the amount of cranking amps that my current interstate megatron battery does. Thanks
Old Jan 17, 2011 | 11:50 PM
LiquidClen's Avatar
Check out Sears DieHard Platinums... will be cheaper than the kinetik and perform just as good
Old Jan 18, 2011 | 12:05 AM
According to sears website they are around $200 which is the same as the kinetik I listed. The sears diehard says it has around 800 cold cranking amps. Not sure what the kinetik has cold but says 1900 in general amps.
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
