Pioneer AVH-P8400BH
Old Jul 4, 2012 | 04:52 PM
  #151
Sufiballer8's Avatar
how much do you think this cost for the player+installation? and can this work on a 2004 automatic g35
Old Jul 9, 2012 | 01:25 AM
  #152
ChrisMan255's Avatar
Has anyone had any problems with their mics? Alot of people have been telling me it sounds like my windows are down when I talk to them on it. And I have tried mounting it a couple different ways. Right now its above the rear view mirror (without the mount). But I called pioneer and they said it may be defective, does anybody else have this problem?
Thanks all
Old Jul 9, 2012 | 05:39 AM
  #153
Wrathernaut's Avatar
Gentle Manne of Leisure
I had some issues before with Pioneer microphones, I've been using the Garmin 010-10804-00 external microphone. No complaints yet, mounted like this:
Old Jul 9, 2012 | 11:33 AM
  #154
teflon_don's Avatar
Thanks all
Yes. I have the same problem with my mic too.
Old Aug 6, 2012 | 01:21 PM
  #155
jgitt's Avatar
so how has everyone been liking the 8400? ive been looking at it and reading reviews everywhere on em. Ive been compiling a list of everything im going to need and i think im finally going to start ordering stuff so i can finally get an 8400 also. So far this is my list. Anything im missing or need to take off? And i have read wrathernauts writeup several times.
AVH-8400BH
DD JDM kit
Wire harness=*PAC ROEMNIS2
steering wheel control harness=*PAC SWI-PS
antenna harness =*Metra 40-NI10 Nissan Antnna Adapter
double din auto on off on switch = tr7 pac
ipod cable =*CD-IU201S
Trim Ring =*Scosche Ddtrb Double Din Trim Ring
Old Aug 6, 2012 | 05:10 PM
  #156
AVH-8400BH
DD JDM kit
Since they dropped the price of the 8400 substantially, it's a lot better unit.
Use the Metra Axxess ASWC, not the PAC SWI-PS. The SWI-PS requires you to solder resistors and must be programmed. The ASWC, on the other hand doesn't need resistors soldered in, and for most units, does not need to be programmed. They're close enough to the same price to be the same, and if you figure minimum wage for your time spent soldering and programming the ASWC definitely comes out on top.
Also, no need for the TR7 with this unit, the video for the rear seats works without it, and there's no reason to have video playing that you, as the driver, can see while the vehicle is in motion. On GPS units, I'd say yeah, go ahead and bypass so your passenger can input destinations while you drive, but there's no reason to do this just for video.
Old Aug 6, 2012 | 05:20 PM
  #157
jgitt's Avatar
but ive read that you lose some of the functionality of it unless you bypass. Such as no appmode or anything is available.
Old Aug 6, 2012 | 05:52 PM
  #158
Just don't use it to watch videos, it's illegal and stupid.
Old Aug 10, 2012 | 06:01 PM
  #159
asco84's Avatar
I'm a n00b here on the forums, and just picked up a 2007 g35x w/ bluetooth no van Wednesday. So far I love the car. I was thinking of replacing my factory unit with one of these Pioneers, but wanted to see pics of a sedan with it installed. Anyone have any? I know the interior is a little different than the coupe.
Thanks
Old Aug 10, 2012 | 07:46 PM
  #160
If you have a 2007 g35 SEDAN, you're in the wrong forum.
Go here: https://g35driver.com/forums/v36-aud...ectronics-375/
You can't replace the factory unit as far as I know, it's too tied in with other systems, but if you get creative with some custom work, you can add a second headunit in a glovebox, center console or elsewhere.
Old Aug 10, 2012 | 09:27 PM
  #161
asco84's Avatar
Thanks!
Old Sep 26, 2012 | 02:39 AM
  #162
blitzace137's Avatar
I'm planning on changing the bose amp when I install the 8400 and a friend gave me his amp that he had on his Honda. The SPX Pro Audio Amplifier does anybody know if this amp a better choice then the stock bose amp on the 06 coupe. Sorry for the noob question.
This is the amp.
http://www.ebay.com/itm/SPX-Pro-Audi...item27cb07ce37
Old Sep 26, 2012 | 11:11 AM
  #163
Same as the identical post elsewhere.
Anything's better than the bose amp, but the amp you've got only will power two speakers.
Old Sep 28, 2012 | 11:43 AM
  #164
Dwalt024's Avatar
IS there a way to wire the 8400 to the OEM Bluetooth Mic?
Old Sep 28, 2012 | 03:03 PM
  #165
Yes. Tap the wires from the mic as they go to the factory bluetooth module.
