Pioneer AVH-P8400BH
Old Nov 4, 2012 | 07:05 PM
  #196
Dwalt024's Avatar
Ahh. Yea I donth really care for the apps. So long as I can use she unit as a screen to display my phone when I use the navi I'm good lol.
Old Nov 4, 2012 | 07:06 PM
  #197
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by broke_as_ajoke
i thought about getting that cable as well, but the pioneer people said it would not allow me to use the apps. I'm in for the answer
The 8400 doesn't do anything with android phones over the cale, it's all over bluetooth - http://www.pioneerelectronics.com/PU...+Compatibility - the AppRadio does some with it over the right adapter.
I'd wait for the next generation of radios with your fingers crossed if you want anything substantial with android compatibility.
Old Nov 4, 2012 | 07:08 PM
  #198
Dwalt024's Avatar
Would it not work with th parking brake bypass? And for that I'd need an mhl cable right?
Old Nov 4, 2012 | 07:20 PM
  #199
MHL doesn't do you any good with the 8400, and it depends on your phone whether it has an HDMI out or just the MHL.
Old Nov 5, 2012 | 10:37 PM
  #200
nubfilter's Avatar
Anyone else have some random issues with the touch screen (stops working/gets stuck until you turn off/ turn on)?
Old Nov 11, 2012 | 04:08 PM
  #201
Dwalt024's Avatar
Wrathernaut - do you have any troubleshooting tips for the backup camera? It is not showing a picture when I shift into reverse. It just has a black screen that states image may appear reversed.
Old Nov 11, 2012 | 04:52 PM
  #202
Make sure you're connected to the right video input (usually the brown RCA connector) that the camera has power (check w/multimeter) and that the camera actually works (connect it to a TV with composite video in).
Old Nov 12, 2012 | 10:21 PM
  #203
ryman546's Avatar
i'm trying to figure out the difference between the 8400 and avh-x5500bhs, any help?
Old Nov 12, 2012 | 11:33 PM
  #204
8400 has dual-zone entertainment options and a detachable faceplate, otherwise they're pretty much feature-identical. But as I talked about (and embedded performance comparison videos) in this post, the 5500BHS has nothing but a higher-resolution screen and much slower performance than the 4400BH, so I'd go with the 4400. I was hoping that the next-gen Pioneer units would have proper support for Android and iOS6 devices, but nope, they just shuffled around the features on last year's units and gave them higher-resolution screens and ruined their performance.
Old Nov 15, 2012 | 11:03 AM
  #205
broke_as_ajoke's Avatar
I have the 8400BH and my question is.. If I install an external (hard drive) 1.5 TB HD via usb to the head unit would it:
1: see the correct drive size?
2: play video?
3: display pictures?
4: will i be able to control it from the steering wheel controls?
5: will the device stream music via. bluetooth (cell phone) to the head unit. The music is does not reside on my cell phone, but on google play. Side note I can play music with google play that is not on my actually device (cell phone)?
Thanks
Old Nov 15, 2012 | 01:12 PM
  #206
2: play video?
Thanks
1. The drive must be formatted to FAT32, so you'll have to use a formatting utility (not the built-in windows tool) to get it formatted that way. There is no stated size limit, but you are limited to 15,000 files in 7,000 folders. (See page 103 of the manual http://www.pioneerelectronics.com/St...nual051712.pdf)
2. With limited video formats - same link and page numbers as 1., above.
3. Yes. Page 36 of manual.
4. Yes, so long as you buy the Metra Axxess ASWC.
5. Yes. Any audio streaming program that can send over bluetooth via the A2DP protocol will work fine. Skip forward/back also work over bluetooth via the AVRCP protocol if your device supports it as well.
Old Nov 15, 2012 | 03:10 PM
  #207
Thanks bro.. I have the android galaxy s3
Old Nov 19, 2012 | 09:26 PM
  #208
Ok I want to start out by saying I got everything installed.. Now I seem to notice a few things.
1: I can't get any radio stations. I read somewhere about someone having that problem, but I can't seem to find it. I got the antenna kit, but that didn't fix the problem. The installer can't seem to figure it out as well.
2: The radio sits flush, but when i try to take the face off it hits the gear shift Does anyone know a good fix for that?
So far the radio is doing what it's supposed to..
Old Nov 19, 2012 | 09:47 PM
  #209
#1 is probably the #1 most common problem from my most common problems (and how to avoid them) list.
https://g35driver.com/forums/6546536-post1050.html
#2 - remove the face while you're in neutral, then shift to park, or trade the car in for a manual transmission.
Auto trans gap:
Manual trans gap:
Old Nov 19, 2012 | 11:15 PM
  #210
Thanks bro... I will let my installer know.
