so my 12" fits...or keep this 10" i just bought
Old Dec 18, 2012 | 09:18 PM
Muski_G's Avatar
If you saw my earlier thread I thought I wouldn't be able to fit my Type R 12" ive had for the past 6 years. So I went ahead and bought a brand new 10" Type S which is now on par with the old Type R's RMS albeit smaller size and magnet
decided to take the packing peanuts and check the volume of my mold....my 12" box was .75 if I can remember and the peanuts filled the mold with more to spare. So now im trying to decide to keep my 12 or stay with the 10
Ive never had a 10 so not sure how it will sound. Thoughts?
went a little too far on the left, will have to trim that way back
Old Dec 18, 2012 | 11:00 PM
broke_as_ajoke's Avatar
Is that enough space for the 12 inch sub.. meaning the air volume needed for the 12 inch to function correctly?
Old Dec 18, 2012 | 11:29 PM
Muski_G's Avatar
I actually have more room than my sealed box I had it in earlier....doesn't look like it but the packing peanuts don't lie!
optimum sealed enclosure is .57 to 1.0 cu. ft.
Old Dec 19, 2012 | 04:25 PM
racercris15's Avatar
keep the 12inch bro
Old Dec 20, 2012 | 11:36 AM
eggyhustles's Avatar
that R is a one note wonder in that small of a sealed box.
Those belong in ported enclosures.
The new type s S is decent and better than the older type r's..use the S
Old Dec 20, 2012 | 07:00 PM
Muski_G's Avatar
i had that Type R in a .75 sq ft sealed box which is the optimal size and it sounded great. this fiberglass mold is actually a tad bit bigger, sure it will sound just as good. probably keep the 12
Old Dec 20, 2012 | 08:36 PM
Muski_G's Avatar
damn, just realized i can no longer get this amp for a dual 2ohm sub
http://www.ebay.com/itm/ALPINE-MRX-M...item3ccd07e8ef
that will only give 300rms not 500
should have bought the dual 4ohm
Old Dec 21, 2012 | 01:12 PM
I guess we all have different definitions of "great"
Old Dec 21, 2012 | 09:42 PM
Muski_G's Avatar
i guess we "do"?
Old Dec 21, 2012 | 09:56 PM
I just plugged the R into winisd
It's flat from 80hz down to around 47hz then it drops down rapidly.
By 30hz, you're down 20db in output.
The S in the same box is a little better with it dropping off around 38hz, but with cabin gain, it'll get you down into the lower 30's.
Ported, they're both completely dff animals
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
kevink
Sep 20, 2015 07:45 PM
SePa_8310
Sep 16, 2015 04:32 AM
Danielek
Sep 10, 2015 06:18 PM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
