How to Add Auxiliary or iPod Input to the Factory Radio
Old Oct 12, 2014 | 10:17 PM
  #181
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by joe19lalo
I have a 06 coupe with Bose and Sirius Satelite.
I just want to go the easy cheap route and tap the satelite adaptor in the trunk with an Aux cable.
I am still a little confused, where to splice.
Any help will be appreciated.
There's no splicing, you just plug the plug that goes into the satellite receiver into the adapter and the plug from the adapter into the satellite receiver.
Old Oct 12, 2014 | 10:22 PM
  #182
joe19lalo's Avatar
Sorry im confused, I just wanted to do option B in the first post.
Old Oct 13, 2014 | 08:00 PM
  #183
Ah, thought you were doing just a cheap aux adapter. That location is fine to splice at. I've updated the first post to identify the wires for the different vehicles, but here's the information again:
The factory service manual for the coupe lists pins 33, 34, 35, 36 on the satellite radio adapter harness for the audio signal, and pins 1,2,3,4 for the sedan. The charted numbers are different, but they refer to the same wires on either sedan/coupe harness. They are arranged in a 2x2 square on one side, so they should be easy enough to identify.
The wire colors at the satellite harness for 2003-2004 coupe and 2003-2006 sedan are:
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
The wire colors at the satellite adapter for 2005-2007 coupe are:
Left+ Blue/Green
Left- Blue/Yellow
Right+ Orange/Blue
Right- White/Blue
The wire colors at the M90 harness at the back of the factory radio are:
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
Old Oct 13, 2014 | 09:34 PM
  #184
joe19lalo's Avatar
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
Left+ Blue/Green
Left- Blue/Yellow
Right+ Orange/Blue
Right- White/Blue
Left+ RED
Left- GREEN
Right+ BLACK
Right- WHITE
Am I missing the cheap aux adapter or is it just USA spec that connects in the back?
Old Oct 14, 2014 | 12:01 AM
  #185
Vanessarino's Avatar
I got my USB3 from GROM about 4 days ago but havent had the time to install. Any ideas on where to put the GROM box? Where to run wires? Only thing I hate is that the cables are too long. Wish they had cable length options.
Old Oct 15, 2014 | 08:04 PM
  #186
Well, the USA SPEC one is cheaper than others, but the "zero-cost" method is just wiring a 3.5mm jack to send an analog signal along the same wires that the satellite radio sends its signal. It requires that you have a satellite radio adapter.
Old Oct 19, 2014 | 01:17 AM
  #187
uz1290's Avatar
Hello all, just recently joined the G35 family .
I have an 03 coupe with the bose system.
It has the SAT button on the radio. I located the satellite harness (white connector) in the trunk.
However, after reading through the comments I am still a little confused as to whether I can or can not add a direct iPod interface adapter. I was wanting to use the PA15-INFI as it had the satellite connection in the trunk. But I saw in the comments that the early 03 g35's were not compatible with any interface other than an fm modulator or cassette adapter. It was my understanding that as long as I had the SAT button and pre-wired connections I could add the iPod adapter.
Can someone please clarify this before I go spending money? Thanks
Old Nov 23, 2014 | 12:58 PM
  #188
When I press my SAT button the radio says "NO SAT" is that the reason my GROM audio doesnt work?
Old Nov 26, 2014 | 04:34 PM
  #189
Drifter2090's Avatar
http://www.gromaudio.com/store/aux1_...emulation.html
Grom has this now its just aux
Old Dec 11, 2014 | 10:05 PM
  #190
Stargate69's Avatar
I'd love to know how to do this myself.
Old Dec 11, 2014 | 11:22 PM
  #191
You've got to be a lot more specific, removing the radio is covered in the DDin installation guide - https://g35driver.com/forums/audio-v...urce-list.html - everything else is more or less plugging the adapters into the back of the radio.
Old Dec 22, 2014 | 04:41 PM
  #192
dunskee's Avatar
Hello, I have a 2004 g35 sedan and I'm just looking for an aux port. I have the satellite harness in the trunk but I dont have a satellite box. Can I still use the pa15-infi or do I need to get a satellite box as well? Thanks!
Edit/// Nevermind i found out I don't need the receiver, just the harness.
Old Dec 22, 2014 | 09:32 PM
  #193
Just the PA15-INFI. Good luck!
Old Dec 23, 2014 | 02:46 PM
  #194
b-dRizZy's Avatar
Any one here Have a Base 06 coupe.. and can direct me to some websites, to have a connection for my ipod with just the headphone jack. Goggle helps but I want to hear some feedback if you have one and if it was a plug and play..
Thanks guys
Old Dec 23, 2014 | 05:09 PM
  #195
First post has you covered. The PA15-INFI. It has an aux input in addition to the 30-pin iPod connector. Just pick up a 3.5mm male to RCA y-adapter.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
