Ok to remove XM SAT receiver?
Old Feb 25, 2013 | 01:11 PM
jmisencik's Avatar
I am doing my DD audio install...completely replacing the BOSE system, is this piece ok to remove? It says XM Satellite radio so I am assuming that is all it is. There were a ton of wires going to it though, so I just wanted to make sure removing it will not affect anything else. It is an 05 G35 Coupe w/ NAV. I am replacing head unit, all speakers, and isntalling aftermarket AMP.
Attached Thumbnails Ok to remove XM SAT receiver?-2013-02-25_12-06-07_326.jpg
Old Feb 25, 2013 | 02:02 PM
GR6RR's Avatar
I removed everything. I even removed the POS BOSE amp. I had to reconnect the wires when I removed it though. there is a wire diagram I found on here and connected based on those colors provided. Maybe this is not the way to do it... but I did it this way. ROFL
Old Feb 25, 2013 | 03:41 PM
jmisencik's Avatar
I am removing all the bose stuff as well. What do you mean you had to reconnect the wires when you removed it? Are you talking the XM receiver?
Old Feb 25, 2013 | 04:52 PM
GR6RR's Avatar
the bose amp.... your stock stereo speaker line out runs to that and then the car speaker locations.
Old Feb 25, 2013 | 07:53 PM
jmisencik's Avatar
Oh ok thanks, I thought you were saying that you had to rewire the wires that went to the XM SAT box.
Old Feb 25, 2013 | 08:22 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yeah, remove the sat box, no need to keep it. You might be able to sell it for a few bucks.
Old Feb 25, 2013 | 09:33 PM
jmisencik's Avatar
Thats what I figured and did, just wanted to double check...haven't hooked up a stereo in a car with this much tech before...last install was in a 1995 300ZX!
Old Jul 9, 2013 | 11:00 PM
NeverEnough02's Avatar
Where is this box located?
Old Jul 10, 2013 | 01:04 AM
Not sure about the 2008+'s you're in the wrong subforum for that year.
But it's probably in the trunk, by the spare or under the rear deck.
Old Jul 10, 2013 | 07:48 AM
Oops! My bad! Got this on a search. I will look under the rear deck. Thanks!
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
Detailed Image
Sep 28, 2015 07:04 AM
