front door speaker wiring help g35 2005 coupe
Old Nov 1, 2013 | 02:05 PM
davis44's Avatar
Hi, i Installed a infinity 60.11cs component speaker set in the front doors. I didn't want to deal with the speaker molex and run speaker lines through to the after market amp in the back, so I decided to use the factory wiring. I clipped the stock woofer harness and spliced the green wire to positive and red to negative to my cross over. Is this correct? Or is Green negative and Red positive?
I am installing
-JVC KW-R900BT In-Dash AM/FM/CD Car Stereo Receiver with Bluetooth
-Infinity 60.11CS components front
-Infinity Reference 6032si rear panel
-Infinity Kappa One Mono Amp
-Infinity Kappa Four 4ch amp
-2 10inch kicker subs.
Old Nov 2, 2013 | 12:54 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yep, green positive, red negative.
Old Nov 2, 2013 | 02:17 PM
davis44's Avatar
Thx a ton, I have another question. I need to tap the harness in the trunk to access the speaker wires to splice so that i can connect them to the amp. Which wires are for the front doors left and right?
Old Nov 6, 2019 | 01:50 AM
G-Lo 650's Avatar
G35 Coupe
did u ever find this out?? im dealing with the same issue
Old Nov 6, 2019 | 03:47 AM
Scorpi0's Avatar
From Bose amp output side:
Driver door: Green+ Red-
Pass door: Green/Yellow+ Yellow-
Old Sep 18, 2021 | 09:13 PM
Xavier Bienaime's Avatar
Cat back, test pipes, k&n intake, short shifter
Amp problems
I am installing
Hey man, i know its been almost 10years but did you ever get your setup working? I doing a similar thing. After market sub amp and speaker amp. I used the speaker wires from the bose amp, spliced it and connected it to the new amp. Im having trouble figuring out the wiring with the headunit and the speakers. Since im still using the bose wires but and aftermarket amp, im not sure which wires should stay connected and im gettingHey man, i know its been almost 10years but did you ever get your setup working? I doing a similar thing. After market sub amp and speaker amp. I used the speaker wires from the bose amp, spliced it and connected it to the new amp. Im having trouble figuring out the wiring with the headunit and the speakers. Since im still using the bose wires but and aftermarket amp, im not sure which wires should stay connected and im getting crazy interference and ground is not the problem.
Old Sep 19, 2021 | 01:54 AM
Scorpi0's Avatar
Here is a list of the wiring and their colors going in and coming out of the Bose amp for an 05 coupe.
Old Sep 19, 2021 | 07:18 AM
I appreciate you bro but i have pictures of the colors. The problem is, i dont know what should be connected or not.
Old Sep 19, 2021 | 12:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
This thread will answer all your questions about the AV wiring, with pretty pictures even!
https://g35driver.com/forums/audio-v...urce-list.html
Old Sep 19, 2021 | 12:41 PM
thanks bro
Slimblj702
Nov 11, 2015 12:58 AM
88irocvert
Oct 17, 2013 01:11 PM
nyckid
Aug 3, 2006 11:52 AM
badbread
Jul 10, 2006 11:06 AM
keltoiskin
Nov 21, 2005 03:32 PM
