Sound Deadening the G.
#169
I used Rammat BXTII recently and it works great.
I put two layers on the outer door panel and noticed a nice change in road noise.
My main goal was to get rid of the rear deck rattle (sedan).
Its not completly gone but its a lot better. Less rattle = more SQ. Sure sometimes I turn it up and the the rear deck sound like **** but the majority of the time its clean.
I like Damplifier and Rammat BXTII. Both are really good products. RammatBXTII is cheaper.
When you hold damplifer in you hand you can EASILY see and feel why the price is higher. The foil on the damp means business.
#170
#171
Lessons learned:
Wear disposable gloves. If you get any on the glove at all change it. If not you will mistakenly be leaving the stuff all over (remember what I said about not forgiving).
Have a piece of cardboard to put the can and straw on if you need to set it down. You'll figure out that the foam keeps oozing out after you let go.
Have plenty of paper towels.
The straw can be a pita. When screwing it on use a small pair of needle nose pliers to hold the spot right beneath the base area of where the straw screws in and tighten the straw. If not it will loosen on you during the work and that can create a mess! If you don't hold it with pliers it will only go on so tight then the whole nozzle spins.
No, I'm not a pro. I started 2 weeks ago to install a head unit, amp, sub and just door speakers. So far I haven't done any actual stereo work; still deadening. I've used about 7 cans of great stuff so far from the least expanding door and window to the big gap filler foam.
I'm also using poly-fill, Stinger Roadkill and 1/8" thick pieces of closed cell foam. The closed cell foam sheet is actually an underlayment for laminate floors called Black Jack. It's 100 sq ft for about $35. Some 3m adhesive spray and you're golden. This is compared to 12 sq ft of 1/8" adhesive backed dynamat foam @ $45.
Good luck
