Sound Deadening the G.
Old Mar 25, 2006 | 10:18 PM
  #61
Bobalude's Avatar
Any estimate on how much add weight total this project added to the car?
Old Mar 25, 2006 | 10:48 PM
  #62
BigSash's Avatar
extremely little
Old Mar 25, 2006 | 11:18 PM
  #63
shooter's Avatar
It's not the critic......
Originally Posted by shooter
Not much..........since I did not cover the car in dynamat (brown bread in my case...1/2 the cost) as others have done.........the spray foam, carpet underlayment and attic insulation are all very light......and i ordered a 35 sq. ft roll of brown bread (12.25 lbs total) but only used about 1/2-3/4 of the roll (6-9 lbs.).....so if i had to guess.......around 20 lbs (equivalent to about 2.5 gallons of gas)......definitely worth the sound improvment
Old Mar 26, 2006 | 12:02 AM
  #64
shooter's Avatar
For all you sedan owners, please check the below thread from mr_ecktid. He had some trouble with foam leaking into his tail lights.
https://g35driver.com/forums/g35-sedan-v35-2003-06/91903-when-diy-goes-wrong.html
Old Apr 19, 2006 | 12:00 PM
  #65
SixFive's Avatar
I did B Quiet Ultimate in my back seat and trunk over the weekend. I was really liberal on the wheel wells and that really paid off. Sitting in the back on wornout Turanza's was actually so bad for tire noise that is was uncomfortable...not anymore. Major improvement. Now I can hear the wind noise that mirrors and A pillar create. This still is no lexus..or even Passat.
Old Jul 27, 2006 | 07:52 AM
  #66
SURFJ9009's Avatar
This is just a great discussion and I am bumping it for others. I am gonna be doing my car soon.
Old Jan 2, 2007 | 03:41 PM
  #67
Marshall2K's Avatar
Planning on performing the sound deadening mod before my audio upgrade. With the pannels off, I might as well run my cables. Thanks for taking the time for this great write up.
Old Jan 2, 2007 | 05:05 PM
  #68
DaygoG35's Avatar
For aftermarket speakers, is it advised to replace stock wires to hi's and mids or are factory wires good enough?
Old Jan 2, 2007 | 08:21 PM
  #69
shooter's Avatar
I used the oem wires for my system and the quality is just fine. I am sure there is someone out there that can comment on the benefit of aftermarket wires.
Old Jan 2, 2007 | 08:42 PM
  #70
caelric's Avatar
It depends on how much power you are running through them. I have a JL 450/4 (150x2 and 75x2) that is running my front mid-bass and tweets. In other words, 150 watts is going to each mid bass and 75 to each tweeter. I wouldn't trust the stock wires for that much power.
50 watts to each speaker should be fine through the stock wire, however.
Old Jan 3, 2007 | 12:23 PM
  #71
DaygoG35's Avatar
Thanks, I have a JL 4 channel amp that I will be using to power my cdt hd 6.5 speakers so I'll run some new cables. Thanks for the info. I try to read all the forums but really never found anything about rewiring for aftermarket speakers.
Old Jan 5, 2007 | 10:49 AM
  #72
Marshall2K's Avatar
expaning foam
I also wanted to add that I have used the "expanding" foam in the past with success and no issues. However, this stuff is not water soluble and is near impossible to "get off". It is imperative to have some kind of protection (tarp, painters floor protection, plastic, etc.) below the areas your treating. The expanding foam will Oooze out holes before it dries. I have had no issues with warping. It is messier than non-expanding foams. It might work a little better in areas that may see moisture/water. Like the G35 sedans rear taillight areas.
Just my 2 cents. Use carefully at your own risk.
Old Jan 5, 2007 | 01:33 PM
  #73
badbread's Avatar
I do not think there is a need to upgrade the factory wires. Unless your going to be running something like 1000+w to your components there is no need. It is a MAJOR PITA to do. I am pretty sure the distance between the amp and the speakers is the biggest factor when doing something like this not the wattage going through the wire.
.02
Old Jan 5, 2007 | 01:44 PM
  #74
digital1986's Avatar
With all the eDead I used I am guessing around 12-18 lbs
Old Jan 5, 2007 | 02:32 PM
  #75
caelric's Avatar
.02
I think the threshold of upgrading the factory wires is not going to be 1000 watts, more along the lines of 100-150 watts. So, if you are running a JL 300/4, which provides 75 watts to each speaker, you should be more than fine. However, if you are running something larger (as in my example, the 450/4, which provides 2 channels of 150 watts each, and two channels of 75 watts), you would probably want to run new speaker wire.
It is a pain in the *** to run new wire to the front doors; but it is certainly do able. I did it, and it was a pain, but nothing you can't do. Best way is to completely remove the doors, that way you have better access to the area where the wire is going to leave the main body of the car and enter in the doors. Whether you run it through new holes you cut, or try and run it through the existing look, removing the doors makes it much easier.
Dave
