Pioneer AVIC-D1/AVIC-Z1 with Double Din Conv. (PICS)
Rating: Thread Rating: 3 votes, 5.00 average.
Old Aug 25, 2005 | 01:16 PM
  #106
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by ariesxtreme
Question...how does the dual a/c controller work...or does it??
Yes it does... with modification.
There's lots of info if you search.
Old Aug 25, 2005 | 04:04 PM
  #107
ariesxtreme's Avatar
I'm wondering how that will work..when I don't originally have that on the car and when you order the dd kit...the new a/c controller does...but I don't see 2 separate temp controllers for it to be dual control. Does that make sense???
~Julie~
Old Aug 25, 2005 | 04:16 PM
  #108
InTgr8r's Avatar
~Julie~
Oh, sorry I didn't pic up on your meaning.
You have to have dual CC 1st.
Old Aug 25, 2005 | 04:24 PM
  #109
Okay so basically...the button will be there when I order the a/c adapter along with the double din finisher but it's not functional...correct?
~Julie~
Old Aug 26, 2005 | 07:30 PM
  #110
BlackonBlackG35's Avatar
~Julie~
Yeah, the controller will just have a "blank button"
Old Aug 26, 2005 | 08:22 PM
  #111
robbdogg's Avatar
Seriously Black - that is sick looking. Great job. Makes me want to go out and do it on mine and make you help me. j/k
Old Aug 27, 2005 | 07:02 AM
  #112
hotice007's Avatar
How do you remove the dash and the stereo? Is there a step by step instructions somewhere?
Old Aug 30, 2005 | 10:11 AM
  #113
regrossman's Avatar
What wires is everyone tapping into for speed sensor and reverse sensor from the D1?
Old Aug 30, 2005 | 01:58 PM
  #114
InTgr8r's Avatar
The speed sensor is at the OEM HU already, just tap in.
I didn't bother with the reverse, not really req'd.
It only provides position correction while in reverse...no biggy
Old Sep 5, 2005 | 10:04 PM
  #115
How to watch video and operate NAV while driving:
_______________________________________________
Hopefully you didn't use every wire on the Pioneer wire harness. Find the wire you didn't use, and just pull it out of the harness.
I used the auto mute lead wire. After you pull it out, you will see that the wire has a connector on the end like this...
There is 1 empty slot on the harness next to the ground wire.
Insert this wire into that slot. You should feel it "click" into place...
Ground this wire and the E-brake wire and you're good to go!!
Old Sep 5, 2005 | 10:47 PM
  #116
InTgr8r's Avatar
Great info..
FWIW, for those that installed the AVIC with a new amp;
I installed a "Matrix" 6 channel line driver from Audio Control,
it boosts the 2v outputs to what ever your amp(s) can handle.
It made an incredible difference in the system!
AudioControl Link
Old Sep 5, 2005 | 10:50 PM
  #117
cfulback32's Avatar
Is that Scosche input adapter useful only if you have bose?
Old Sep 6, 2005 | 12:15 PM
  #118
InTgr8r's Avatar
Sighhhhhhh....
Guess I gota pull the HU again
Old Sep 7, 2005 | 12:41 PM
  #119
Sighhhhhhh....
yeah, I pulled mine twice in less than 24 hours....
Old Sep 7, 2005 | 01:08 PM
  #120
InTgr8r's Avatar
LOL, Yah I kinda figured that...
You no sooner did your speed switch fix & BAM new work around
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
