Selling Sirius Sat
Selling Sirius Sat
I'm selling mine, just got it about a month back and it still has 2 months of free subs.
Reason for sale, I thought I would be commuting a long way, but with the new job, I'm only 10 min away, so can't justify the monthly subscription.
Its a month old Sirius bought from Grubbs, with the Terk low profile antenna, paid about 360$ for it, please send me reasonable offers if interested, thanks.
This is the factory sat sirius reviever with the smaller, better antenna. It pluggs right into the sat cable if you have it in the trunk, with no wires cut. You can see the unit on grubbsperformance.com.
IF you have to cut wires, then that's probably why you should have it installed. If all you do is plug the sat wire in your trunk to this sat receiver, then you dont have to pay 800 bucks to do it, your being ripped off. Just buy the reciver and install yourself like I did, the dealre quoted me the same thing, and I said screw you
Look in your trunk, have to open a panel in left side of your trunk, next to the spare. If you see a white colored pugg, you are in luck.
ALso, does your dash radio have the sat button? If yes, then again you most likely have it, but either way, look into trunk.
The sat wire powers everything, very easy install. Do a search, you will find tons of info. ALos check out 6mt.net, also good info there if you search. I think there was a DYI in the DYI section.
