Lack of drivers seat headroom? Easy, easy $0 Fix
Old Jun 16, 2007 | 04:48 PM
  #61
GWord256's Avatar
Some advice.
1- Did you move the nut towards the front of the car?
2- Slide the rubber peice right next to the nut when you are done. The seat motor will stop turning if it thinks there is an obstruction in the way. The rubber washer will make the seat think this, it happend to me.
3- Do not turn the nut so tight towards the end. Leave a slight gap. Again if the seat thinks there is an obstruction it will stop. If the nut is too tight it could be causing the seat to not move.
4- Does the seat give any reaction at all, then stop? Or does the seat not even try to move? If it's not even trying to move you may have loosened a electrical connection. Check the wiring.
Originally Posted by Bobyl573
i've been trying this mod all morning and i can't get it to work!! when i grip down hard on the nut ( after i moved the washer and rubber piece back for more room) the seat won't move at all. If i let go a little bit than the pliers start slipping and i can't get a hold of the nut.
Old Jul 4, 2007 | 05:42 PM
  #62
IvoryGT's Avatar
I just did this after figuring out how exactly the nut thing worked.
basically there are two nuts one behind the other, the one closer to the front of the car is a stopper for the one behind it, so instead of making the car go up and down to adjust it. I just use my hand and twisted the nut closer to you counter-clockwise far enough till you can see the stopper nut.
Then use a set of pliers and start turning the stopper clockwise until it's almost as far as it can go towards the front plate. then now manually turn the other nut back clockwise till it touches the stopper nut.
Now im definitely sitting lower and doesn't feel like Im on a platform while driving..hah.
Old Jul 14, 2007 | 08:01 AM
  #63
Blue Lion's Avatar
I will try this today...thanks for the posts. I'm 5'11" and after long trips need an Advil. I have the sunroof and need the extra space.
Old Jul 14, 2007 | 11:16 AM
  #64
GWord256's Avatar
FYI: Take headach medicin for extended trips it's got caffine and asprin in it.
Old Sep 19, 2007 | 10:37 AM
  #65
barrister89's Avatar
I just got my 07 G w/sunroof, and my seats are different from those in the pictures. However, I found a threaded rod with a 13mm aircraft nut on the end that acts as the stop for seat height, which is accessible from under the front of the seat rather than the rear. Quite easy to reach and by backing it off a ways I ended up with another inch or so of headroom.
Of course, try this at your own risk.
Old Oct 28, 2007 | 05:00 PM
  #66
Killa22's Avatar
Old thread but i just did this and am amazed. i wish i knew this earlier. I'm about 6'2" and always had a sore back after driving long distances but now I'm comfortable with my extra inch or so of head room
Old Nov 17, 2007 | 11:09 AM
  #67
Kazaam's Avatar
BUMP for a great mod. I'm gonna try this out today!!
Old Nov 18, 2007 | 07:35 PM
  #68
John Henry's Avatar
Sweet mod! I'll be trying it soon.
Has anyone found any drawbacks to this? Any loose seats or lack of power controls?
Old Nov 18, 2007 | 08:32 PM
  #69
GWord256's Avatar
From the amount of people that have done this and the lack of complaints, I'd say no one has had any backlash.
Old Nov 18, 2007 | 10:08 PM
  #70
John Henry's Avatar
Yeah, good point.
(BTW, just read your weight reduction thread. Cool thread and a cool project!)
Old Nov 19, 2007 | 11:58 PM
  #71
Fiji's Avatar
Has anyone tried this on an 06? I saw barrister had good results with an 07. Not sure when they changed the seat styles. Been searching for a used 6mt w/out sunroof forever now but if I can get more clearance on an 06 w/SR I will be driving it tomorrow!
Old Mar 1, 2008 | 01:30 PM
  #72
anotheraznguy's Avatar
does this only work on the g's power seats?
the link to yahoo pictures is dead..
Old Mar 18, 2008 | 04:51 PM
  #73
G35_7o2's Avatar
pics are dead anyone care to post new pics or re-post?
Old Mar 18, 2008 | 05:21 PM
  #74
IvoryGT's Avatar
it's pretty straight forward if you can squeeze your head and your hand under the seat.
Old Mar 21, 2008 | 07:39 PM
  #75
neight's Avatar
i gotta try this i def feel the seat is too high and i'm not even that tall sorry for you tall as$ guys
