DIY: Cutting Rear Springmount aka "the springmount mod"
Old Jan 27, 2009 | 12:12 AM
  #151
DrrSeuss's Avatar
word of advice guys...never put your stock springs back on and leave your spring mounts cut. Your tires will be eaten up. My falken 452s that only have 3000 miles are now completely bald. I didn't have time to order the new spring mounts and now I have to get new tires.
Just thought I would add this to the thread, just in case there's other dumbasses like me.
Old Jan 27, 2009 | 12:20 AM
  #152
jlin615's Avatar
Another word of advice. Carefully measure and cut the springmount, give it some padding maybe quarter inch. My front and rear is so dead even that just a slightly slope surface makes my rear look saggy.
Old Jan 27, 2009 | 12:13 PM
  #153
spankey167's Avatar
And you cut how much? 1/2 inch? So your saying we should probably cut 1/4 or a 1/3 of an inch?
Old Jan 27, 2009 | 12:59 PM
  #154
jlin615's Avatar
Every car will be different, some people even cut 1 inch.
Old Jan 27, 2009 | 01:25 PM
  #155
RBull's Avatar
Rated M
Why?
I am running stock springs and cut spring mounts. My tires aren't eaten up.
You sound like you have an alignment issue.
Old Jan 27, 2009 | 03:49 PM
  #156
redlude97's Avatar
1/2" is perfect for 350z h-tech is you use the correct tire size
Old Jan 27, 2009 | 03:51 PM
  #157
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by RBull
Why?
^+1
Has nothing to do with the mounts DIY.
Old Jan 27, 2009 | 04:29 PM
  #158
str8dum1's Avatar
heres mine on h-techs with maybe 1/2" or so on the springmount mod
Old Jan 27, 2009 | 06:36 PM
  #159
mt7rabbit's Avatar
Why?
+1 I had my stocks put back on with 350Z S Techs, 20/25mm spacers, & .5" cut on the springmounts with out any issues at all. Sounds to me like you cut the springmounts and did not get an alignment to make up for the drop.
Old Jan 28, 2009 | 07:42 PM
  #160
spankey167's Avatar
I am going to be running a 275/35/19 in the rear. Would you consider that a correct tire size for 1/2" cut to the spring mount?
Old Jan 28, 2009 | 08:02 PM
  #161
redlude97's Avatar
If you are using a 245/35/19 or 255/35/19 in the front, then yes
Old Jan 29, 2009 | 01:33 AM
  #162
Sponger's Avatar
6MT Brembo Coupe
I did the rsm on my z htechs and did it again after putting in my z stechs. Teins don't drop the rear enough.
Old Jan 29, 2009 | 01:36 AM
  #163
Gdup35sedan's Avatar
ENVautoDetailing.com
That would be an alignment problem, not the springmount being cut.
-GP-
Old Jan 29, 2009 | 09:44 AM
  #164
jlin615's Avatar
How about G S-techs?
Old Jan 29, 2009 | 10:04 AM
  #165
Sponger's Avatar
6MT Brembo Coupe
I don't think you need a rsm with those, only the Z springs. The spring rates on the G S-Techs are horrible.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
