DIY: Spring Install Only
Rating: Thread Rating: 3 votes, 5.00 average.
Old Aug 5, 2010 | 07:50 PM
  #76
ray1370's Avatar
Originally Posted by or_G
Do I need a compressor when installing a GF210?
You'll need it if you're installing just springs.
Old Aug 16, 2010 | 12:47 PM
  #77
nsp106's Avatar
I bought and installed the Eibach Pro-kit a few weeks back. The front sat down really nice. Will need a camber kit tho. But the back rose a 1/2 inch and still has not settled down. I was thinking about cutting the spring 1/2 of a loop. Is that a good idea? Would like some thoughts.
Thanks
Old Aug 16, 2010 | 03:10 PM
  #78
OKStateG35's Avatar
Thanks
Generally, I don't think it's a good idea to cut springs. I would check to make sure they are installed correctly because it should not have lifted you at all.
Old Aug 18, 2010 | 10:51 AM
  #79
G35CDriver's Avatar
Double Check install... Cutting springs is not advised.
Old Sep 13, 2010 | 06:19 AM
  #80
mjholla19's Avatar
Also a impact wrench or air tools can be used with spring compressor
Old Sep 13, 2010 | 06:21 AM
  #81
mjholla19's Avatar
Nice diy tho
  #82
mjholla19's Avatar
Cutting stock springs is not the best idea im not sure about cutting aftermarket springs though
Old Sep 24, 2010 | 01:34 PM
  #83
sena's Avatar
nice write up. looking to do a set of coils soon. this should help alot!!!
Old Oct 18, 2010 | 12:39 AM
  #84
jw973's Avatar
good write up.... how long would you estimate the spring change took? and are coupes having to run a camber kit for the tein s-techs....
Old Oct 18, 2010 | 09:57 AM
  #85
G35CDriver's Avatar
The rears take about 15minutes and the fronts about 30 per side...
You might be ok without a camber kit but it is up to your personal style.
Old Oct 20, 2010 | 06:37 AM
  #86
jw973's Avatar
good deal.... seems simple... i plan on doing this in the next couple weeks... will check into the camber kit as well.... thanks
Old Nov 9, 2010 | 11:16 PM
  #87
Footballmania32's Avatar
Any tips for preventing the shock piston shaft from spinning while trying to disassemble the strut??
Old Nov 10, 2010 | 11:54 AM
  #88
G35CDriver's Avatar
I had held it in place with a pair of channel locks. Hope that helps.
Old Jan 18, 2011 | 04:27 AM
  #89
Meatshackle's Avatar
Deep Sea Moderator
Great DIY! Swapped my springs last night.
Thanks!
Old Jan 18, 2011 | 02:08 PM
  #90
G35CDriver's Avatar
No problem, glad I could help.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
