DIY: Spring Install Only
Old Jul 28, 2011 | 09:02 PM
  #106
IIIHawKIII's Avatar
you tilly swat!!
Old Jul 28, 2011 | 09:46 PM
  #107
G35CDriver's Avatar
Sorry guys! How is the thread looking now? Happy installing
Old Jul 28, 2011 | 09:56 PM
  #108
IIIHawKIII's Avatar
you sir, have won the interwebz.
Old Jul 28, 2011 | 10:15 PM
  #109
G35CDriver's Avatar
I try
Old Aug 3, 2011 | 07:07 PM
  #110
IIIHawKIII's Avatar
ok, i'm trying to get my strut out to swap springs...i've followed the DIY and the youtube video, but for some reason, my strut isn't moving freely like the video. it's like it's still got a load on it.
i'm a big guy and i'm yankin on this thing like there's no tomorrow and i cant get it out. it won't come down from where it meets the body at all. like when it says to "slide the lower fork forward" my fork won't move. i mean, if i STEP on the control arm, then it might, but i don't want to break anything...
how hard can i shove down on the control arm assy? but it doesn't seem like it would matter because it's held in place by the lower endlink....
any help is appreciated.
Old Aug 3, 2011 | 11:54 PM
  #111
G35CDriver's Avatar
If you have removed all bolts as listed the strut should move with little to no force. Any photos to show your issue.
Old Sep 10, 2011 | 03:18 PM
  #112
Kamikazejs's Avatar
It should be ok to push down the lower control arm a little to pull the strut down. I had to and did.
Old Sep 29, 2011 | 11:26 AM
  #113
PERKS11's Avatar
thanks for this. this will help when I install this weekend.
Old Sep 29, 2011 | 12:30 PM
  #114
G35CDriver's Avatar
cool, good luck.
Old Oct 12, 2011 | 07:13 PM
  #115
Pj1594's Avatar
Lol did this today tried everything to get the bolts off the shock even resorted to stepping on the wrench that's 200 lb not even a budge!
Old Oct 12, 2011 | 11:12 PM
  #116
G35CDriver's Avatar
Hose it down with PB blaster and buy a large breaker bar.
Old Oct 13, 2011 | 05:43 AM
  #117
IIIHawKIII's Avatar
You have to secure the bolt. Use a breaker bar. Have both sides of the front of the car up.
Old Oct 13, 2011 | 01:32 PM
  #118
Pj1594's Avatar
I tried wd40 nd a breaker nothing happened what else can I do no matter how much pressure I use I won't get Anywhere
Old Oct 13, 2011 | 01:37 PM
  #119
Pj1594's Avatar
And I jacked it from the jack point under the engine
Old Oct 13, 2011 | 04:33 PM
  #120
IIIHawKIII's Avatar
PB Blaster is better than WD for breaking stuff loose. if you can't get it, you might have to call a shop. have access to an impact gun?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
