View Poll Results: wat problems r u having?
installed spacers, have ABS, Slip, VDC lights on
29
18.01%
installed spacers, have knocking
4.35%
installed spacers, have both lights and knocking
3.73%
didn't install spacers, have no problem
40
24.84%
didn't install spacers, have one of the problems above
4.35%
didn't install the camber kit yet.
43
26.71%
installed spacers, no problem
29
18.01%
Voters: 161. You may not vote on this poll
SPC Poll
Old 07-13-2007, 10:13 PM
mark4x4's Avatar
^ If you bought them from Peter at IAP, I would talk to him because depending on your setup, the amount of drop and your spring rate will determine whether they should work or not. If you decide to install them and you do get the knocking issue, SPC can send you disc spacers for the stock bump stops which should solve all the knocking issues.
If you are not satisfied with the results, I personally can't speak for SPC although they have been excellent when it comes to customer service. I would assume they would give you a refund but I would check that out before you install the arms, then you can go in a different direction.
Mark
  #257
Old 08-02-2007, 08:03 PM
G35BASTARD's Avatar
Does anyone have a picture of the bracket that gets bent and is causing this issue?
Thank You.
  #258
Old 08-03-2007, 10:50 AM
Tru-G's Avatar
Thank You.
Take a look at the pic on post #254. It is the L shaped bracket with the 2 holes on the bottom left.
  #259
Old 08-13-2007, 02:48 PM
blind_side1's Avatar
Wanted to share my findings. I have a 2005 G35 6MT. After installing the SPC front and rear kits, all my dash lights were on.
I contacted SPC, and an engineer told me to move the bracket around and bend it in a little towards the hub until the ABS light went off. I did that, but the slip and VDC lights remained on.
Going back to the document I used to install the REAR kit written by Chad Protocav called "Installing the SPC Toe Bolts on a Nissan 350Z or Infiniti G35 Coupe," it states the slip light might come on because the car is so far out of alignment that the tires are scrubbing. Knowing this, I decided to get a four wheel alignment and stop messing with the ABS sensor. Happy to say that after the alignment, all my lights are off and everything seems to be fine. Oh, I also installed the Eibach pro kit at the same time.
  #260
Old 08-13-2007, 03:05 PM
lekker_droom's Avatar
This is exactly correct, same thing happened to me, quick alignment fixed it.
  #261
Old 08-13-2007, 03:08 PM
THMotorsports's Avatar
Im glad to see that everyone is getting positive results. We should make a list of those who are having problems, and see if its based upon the suspension ran so people can know in the future. I know if your down 2"+ like the tanabe's, its gonna hit once in a while. But for those 1.0-1.7, it seems like its defect free.
New poll?
  #262
Old 08-14-2007, 09:46 AM
izmir41500's Avatar
G35driver Addict
getting them installed today...we'll see how it goes.
edit: well the spc a-arms and basics are on in the front. I'll have to wait for the rears. I'm a little higher than stock right now so we'll have to wait and see what happens when i drop it low.
  #263
Old 08-29-2007, 12:29 PM
05BlkG35Man's Avatar
I installed the Front and Rear SPC camber kit and i'm having the "christmas tree" syndrome. Also,my brakes are bitting and you can hear a air pumping noise when the car first starts up and you drive it( i would assume it's the car checking the abs). Thursday i'm going to take it back in and remove the extender bolts. The car is already aligned up so hopefully this helps.
  #264
Old 09-18-2007, 12:34 PM
izmir41500's Avatar
G35driver Addict
the revised arms aren't hitting, and i haven't installed the spacers yet. i need to since i need a lot more positive adjustment up front. i'm afraid of my dash lighting up with the abs and what not.
  #265
Old 09-20-2007, 11:09 PM
Quick 1 month follow-up. Since the alignment, I've had no problems with the dash lights. I have also not felt any rubbing or had any other problems. I do get many compliments on the car's stance.
  #266
Old 09-23-2007, 06:31 PM
Don@TireOption's Avatar
I sent you a PM blind_side if you could please reply when you get a chance..
  #267
Old 10-18-2007, 11:09 PM
htown,
PM sent back. Sorry about that. I don't check this site too often.
  #268
Old 10-19-2007, 08:47 PM
Sent you another PM, thanks!
  #269
Old 10-26-2007, 10:16 AM
G35-24's Avatar
Install The Front A Arms With The Spacers And The Rear .
No Problems Here. Car Drive Like A Dream
  #270
Old 10-28-2007, 10:01 PM
G37Rider92649's Avatar
Installed front camber with spacers here.
Big problems. Car drives like s**t.
VDC Lights, Slip, and ABS on, what do i do.
Already ran an alignment, didnt help.
What now?
SCREW G35 SUSPENSIONS, THEY ARE A JOKE
SCREW SPC, THIS IS A JOKE
THMOTORSPORTS IS BADASS THO, I LIKE EDDIE!
Quick Reply: SPC Poll
