G35 Compression Rods are Total Crap
Old Oct 9, 2009 | 05:05 PM
  #286
AARONHL's Avatar
I removed the compression rod from the noisy side. The joint moves all around by hand, but I don't hear any noise. I'm guessing the bushing looks alright?
The lower ball joint nut is rusted on the ball joint bolt. So when I try to loosen the nut it turns the bolt as well. I don't know how to get it off!!!
Old Nov 11, 2009 | 05:54 PM
  #287
thescreensavers's Avatar
Mr.202?
Well, it seems my car as this problem. When driving into driveways the front end makes a sound very similar to the ABS testing sound, as well as if I come to a stop and put my car in park on a slight incline you can hear the noise as well. I guess this is the problem everyone else is having. Once my Axle ticking gets worse I'll bring it in for repair.
Old Nov 24, 2009 | 04:08 PM
  #288
Mr.202?
Is this considered "Drivetrain" problem?
Old Nov 24, 2009 | 08:03 PM
  #289
G35fromTO's Avatar
No it wouldn't be.
Old Nov 24, 2009 | 09:40 PM
  #290
racertech's Avatar
Is this mostly happening to only sedans? The day I lowered my coupe on tein basics, there was no noise till 300 miles later. Sounds like a small thump only on slow driving through rough roads n alleys according to bumps
Old Dec 3, 2009 | 01:21 AM
  #291
bocatrip's Avatar
I glad to see that my thread is alive and doing well after over 2 years!!
Old Dec 3, 2009 | 03:38 PM
  #292
OCG35's Avatar
^^^ the problem will always exist - so I'm sure the thread will remain for a long time...
Old Dec 6, 2009 | 05:18 PM
  #293
Dan_K's Avatar
Does the creaking noise happen over bumps or when coming to a stop? When I brake semi-hard and my car's front suspension is loading, I can hear the creaking and when the suspension rebounds, I also hear a creaking noise. Are these the symptoms?
Old Dec 8, 2009 | 02:34 PM
  #294
biochemist's Avatar
Is this problem related to time, mileage, and how it's driven or any combination there of? The reason that I ask is that I have an 06 sedan that I purchased at the end of the year in 2006 and now have only 17,000 miles on it. While I still have more than a year left on my 48/60K warranty, not sure if I'll put any significant miles before the basic warranty expires.
Guess the same thing can be said about the rocking back and forth of the driver seat and the spark plug coilover covers.
Old Dec 9, 2009 | 12:25 PM
  #295
Q451990's Avatar
If this noise is what I hear on our G, it's been doing it since new. I notice it in cold weather going over bumps... like the end of the driveway. I'm waiting until the end of the warranty to get them replaced.
Heath
Old Dec 16, 2009 | 02:18 AM
  #296
sliderg35's Avatar
Mine started with the squeak - I didn't really care about that. It has now turned into a clunk and the dealer says it's the compression rods. He want $1,200 just for parts. I'm in Victoria BC. I think I'll give Riverside the order on this one.
Old Dec 16, 2009 | 02:51 PM
  #297
OCG35's Avatar
just order the bushings and have them pressed in... lots cheaper.
Old Dec 30, 2009 | 08:56 PM
  #298
sliderg35's Avatar
OK, I replaced the compression rods today. They came without the cone (as I had requested) but I bought a pulley puller and yanked the old ones off myself. All of the front-end clunking is GONE! It cost under $400 Cdn. I don't know how the dealer can keep a straight face when they give you a ridiculous quote like that. The first one took me a bit longer because of the problem getting the cone off, but I got the second one installed in less than 5 minutes (including getting the cone off). When you take the end with the ball off, it can be tricky to unscrew the nut because there is nothing holding the bolt steady. I used an impact wrench and it popped off nicely.
Old Jan 24, 2010 | 07:19 PM
  #299
Braintree's Avatar
For those that have replaced their bushings, some quick questions:
1) Has anyone had to replace them a 2nd time? Y/N
2) Is there a newer/better material out there (e.g., polyurethane) for the bushings or are we stuck with the rubber ones? Y/N
3) If you replace the bushings, is it a good idea to also replace the rubber boot on the other end while you're in there? Y/N
4) Someone suggested simply tightening the nut at the bottom end of the Rod, beneath the bushing, as a solution-- is this a realistic solution? Y/N
Any advice is welcome. Thanks in advance.
Old Jan 25, 2010 | 03:03 PM
  #300
Bumba's Avatar
It turns out that my bushing had gone bad on the wheel end of my compression rod. Unfortunately I special ordered the bushing and am unable to return it and have no use for it.
If you're interested PM me. The part number is: 54570-AC70A
