Any one replace their lower ball joints?
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jul 9, 2013 | 03:18 PM
  #211
DGrantG's Avatar
I got mine off eBay. Haven't had a chance to get on the highway yet. I had vibrations b/c my tires were choppy and I need and alignment. New tires will be here tomorrow and I'll be getting them put on this weekend along with new shoes and an alignment.
Old Jul 9, 2013 | 03:45 PM
  #212
joedaddy1's Avatar
there are like 40 different brands on eBay...
which one did you order?
Old Jul 9, 2013 | 03:48 PM
  #213
DGrantG's Avatar
These are the ones I ordered. I wouldn't recommend getting these because, as you can see in the photo, the rubber boot also covers what I call the pressing flange, which is the part you put the force on to press the ball joint into the control arm or hub, whatever it's called in our cars. I was very afraid that I was going to tear this and all the grease come out so I was extra careful when pressing it in.
The good thing about these though is that they come with a 1 year warranty.
http://www.ebay.com/itm/290908988293...84.m1439.l2649
Old Jul 30, 2013 | 12:21 PM
  #214
rwr's Avatar
rwr
hello - i have a quick /strange question! i called megan racing!-& there saying that they dont have a lower ball joint for the front ('03 G coupe) just the center adjuster! can this part be used for the lower ball joint (the center adjuster-?- thank you
Old Jul 30, 2013 | 12:51 PM
  #215
Blue Dream's Avatar
I drove ttrank's car solo
The roll center adjusters Megan sells are the replacements for the lower ball joints. They are just designed differently so the return the steering angle to the correct position on lowered cars. If you aren't dropped, these are overkill since they're over $200/pair.
FWIW I'm having mine installed tomorrow, yeah!!
Old Oct 4, 2013 | 12:05 PM
  #216
Dr.Bora's Avatar
Where else can i get ball joints aside from CZP?
I know dealer and fleabay, just seeing what else is out there. Not lowered yet but intend to do a mild drop in the near future
Old Oct 4, 2013 | 10:05 PM
  #217
blAk mAx's Avatar
autozone or advanced auto carries one
Old Oct 24, 2013 | 10:53 PM
  #218
wills06g35's Avatar
I replaced mine with the megans, im lowered. having an issue with right side, the nut that connects the balljoint to the lower control arm continues to come loose. This is causing the nut to tear into the lower control arm. Not sure if there is a problem with the balljoint seat. Anyone else having an issue?
Old Oct 31, 2013 | 01:33 AM
  #219
coffeysm's Avatar
Both of my ball joints need to be replaced as well; I checked out RockAuto and they have two from BeckArnley and Deeza. Has anyone used any of these?
Old Oct 31, 2013 | 03:21 PM
  #220
a_bains's Avatar
I would also like to know if anyone has used these.. $45 (Deeza - have 2 year warranty) and $60 (Beck) ..
Not sure if I really like the metal ring clips that hold on the boots.. It just looks cheap.. thoughts?
Has anyone used the CZP ball joints?
Old Oct 31, 2013 | 05:59 PM
  #221
coffeysm's Avatar
I ordered two Deeza from RockAuto and should be here tomorrow hopefully. I'll let you know my thoughts on them.
Old Nov 1, 2013 | 04:57 PM
  #222
coffeysm's Avatar
I got my Deeza ball joints today and they look pretty solid, but they don't have castle nuts or cotter pins. Here are some pics I plan on trying to install them this weekend.
Attached Thumbnails Any one replace their lower ball joints?-img_20131101_164632.jpg   Any one replace their lower ball joints?-img_20131101_164715.jpg   Any one replace their lower ball joints?-img_20131101_164725.jpg
Old Nov 3, 2013 | 09:38 PM
  #223
coffeysm's Avatar
So I just pressed on one of the Deeza ball joints. The Deeza is not flexible at all like the OEM ones.
I used a 22 mm socket, ratchet, 22 in breaker, and the press from advance auto. Took about 5 minutes to do.
Does anyone know if any of the other ball joints are as movable as OEM?
Oh yea Deeza nut is larger than OEM had to use 15/16 to get it on 22/23 mm was to small.
Old Nov 3, 2013 | 10:11 PM
  #224
blAk mAx's Avatar
moveable as in loose? i would think loose is worse
Old Nov 3, 2013 | 10:24 PM
  #225
AARONHL's Avatar
Why not just reuse OEM nut? What do you mean by loose?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
